hit a bump and truck shut off??????
I have had cases where a bump causes stalling and have found the culprit to be the CPS. Even a small bump like when you leave the garage floor can cause it to kill the engine. In this case it would restart and act normal until next bump. Inside the CPS there is a Hall sensor which have sensitive components that could fail after years of use. As stated above, this problem could be caused by various of different things, but I will mention the CPS due to my earlier findings.
Helge
Helge
Last edited by helgaairhead; 01-12-2019 at 04:28 AM. Reason: Bad norwegian spellling
FordBlueHeart
12-17-2017 09:16 PM
mikefred44
03-22-2016 05:34 PM
travismoore
15
02-11-2016 05:16 PM
ford_raptor
09-10-2009 04:13 PM
