Heavy duty lift coil springs
Old 07-30-2009, 09:47 PM
Ford4x4-JD70AB's Avatar
Ford4x4-JD70AB
Ford4x4-JD70AB is offline
Ford4x4-JD70AB is starting off with a positive reputation.
Does anyone have a good source for heavy duty lift coil springs (4 or 6 inch) for a 92-96 f150? I'm getting ready to do a solid axle swap on my 95 f150but Im afraid that regular lift coils wont support enough weight...especially since I have a heavy bumper and diesel engine up front. The 2.5" rough country lift coils I have now are just barely cutting it. I considered seeing if lift coils for a 05 or newer super duty (diesel) would work. Has anyone heard of trying this?
Old 11-24-2009, 04:41 PM
fordtech300
fordtech300 is offline
fordtech300 is starting off with a positive reputation.
JD70AB,
I have a 96 that I converted to 4wd with ttb. I work at a dealership had spotted a set of 07 S/D diesel springs in the scrap metal pile (there is an SSM or TSB about squeaking I think) I Installed them without modification but found that they are very harsh. My truck is a stock 300 - 6 without A/C or added weight. - the upside is that they raised the front end about 2.5 - 3" but without drop brackets on my pivots and arms, I cant get the alignment even close. I'm currently looking for the gas versions of the same springs as they appear lighter although I'm not sure on the spring rate - the best case would be if those springs were attached to a complete axle so I could kiss the ttb goodbye.
resonateur
10-26-2015 10:01 PM
Whatsinthebox
04-18-2015 05:57 PM
kras498
General Automotive Discussion
03-12-2015 11:43 PM
ATS Junior
Vendor Specials, Discounts, Product Announcements & Group Buys
07-29-2014 09:14 AM
tjames001
2004 - 2008 F150
08-04-2012 09:47 AM
Quick Reply: Heavy duty lift coil springs
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
