Engine swap
Old Jul 29, 2009 | 03:18 PM
80sFBOMB's Avatar
80sFBOMB
Engine swap
I have a 85 f250 with a 460 and a four speed I want to put a small block in what engine will fit? Which engine will fit the current bellhousing? What other options do I have? Will the flywheel and clutch work?
Thanks for any help!
Old Jul 29, 2009 | 03:36 PM
Conanski's Avatar
Conanski
You'll need a SBF bellhousing for a 351W, but a 351M would bolt right up.
Old Jul 30, 2009 | 12:47 AM
hittman1422's Avatar
hittman1422
why small block? and ford made 2 bellhousings... small block and the big block... can you guess what the 460 is lol... unless you already have a small block to put in i'd stick with the 460, they're great motors
Old Jul 30, 2009 | 11:16 AM
flxiclese's Avatar
flxiclese
351m or 400m are direct swaps, bolt right to bell housing. Think the distributors are interchangable as well.
Old Jul 30, 2009 | 06:21 PM
ctubutis's Avatar
ctubutis
Correct.
Also correct, he can use a dizzy from any 335-series engine.
The 400 makes a GREAT truck engine (used for truck purposes of pulling &
hauling), it has the longest stroke of any Ford engine ever made.
