Error at the pump, FTE probably helped saved me!
Going through Sturgis to help a friend move, I decided to get $40 in Diesel to make sure that I got back home. (overhead showed 126 miles until empty.) Anyway about 22 miles down the road pull into Newell and as I slow down, the engine starts sputtering and white smoke is coming out the exhaust. Remembering some of the things that I've read on the forum, I decide to pull over and drain the fuel bowl. Sure enough it smells like gas. Anyway, look at my reciept and it says Diesel. I call the station, and they said they were changing the pump over to Premium for the Rally. I told them that I had 16 galloms of it in my Diesel. Gave me the mechanics #, and they talked me into purging the diesel out of the beast. Fortunately my friends neighbor had some tractors, so she took the mix off my hands after I got it all out. What a pain!
Just thought I would share... Just because the pump says Diesel, it doesm't mean that's what is in there.
Fortunately, after filling the bowl, filter, and adding Sea Foam and Diesel Kleen, it is running fine. Got lucky I guess...
Yea if your truck is at all damaged you may want to tell the station they'll be fixing your truck since you paid for diesel and it pumped out gas.
Your injectors may be shot. They should buy you a set of single shots.
You guys are all older than myself and more mature because if it was me I wouldn't be this calm. I'd be foaming at the mouth if it was my truck.
I would have been quite mad as well, but in those moments getting irate wouldn't have gotten you anywhere. Good to know you were able to get it all pumped out and swapped, that station should have put a clear sign out.
I know out here our diesel pumps have large diameter spouts to prevent gas people from putting diesel in there cars but you can help if they have the wrong fuel in the tank...
So lets say you didn't have what he had available and you pump in 20 gallons of gas...what can do you add to the mixture to drive it safely..someone mentioned 2 cycle oil?? How much..just in case..I get a stupid moment?
What if your tank was nearly empty and you filled with gas...what can you add to it in that case....thanks Craig
A lot of gas in your diesel tank. Drain tank, and refill with diesel.
He did call me back on the next day and said that I had caught them just as they were changing the pump. I said that since I paid for $40 of diesel, and $37 for a filter and there was no damage, I thought it would be fair to get $77 in Diesel. When I came in they said to get $80, so we called it good.
There are now signs on the pumps, black nozzles, and hoses wrapped in bright tape to draw attention...
