What causes a F250 powerstroke diesel to keep running when ignition switch is turned off?
New ignition switch installed still not shutting off. Have to remove Powertrain EEC Relay #302 to get it to shut off and with it removed it will start and shut down!
I would start by looking for a couple of wires that are shorted together. If the truck runs with the relay out then power is being bypassed on the relay portion .
