loss of power
Old 07-25-2009, 09:58 PM
jb65542's Avatar
jb65542
jb65542 is offline
loss of power
i have a 96 f150 5.0L auto. it dont have the power it did and only getting 10 mpg. the scan tool had 2 codes egr insufficient flow detected and secondary air injection pump. anyone have any ideas.
Old 07-26-2009, 12:30 AM
89F250_7.5's Avatar
89F250_7.5
89F250_7.5 is offline
took me and a certified tech a fair amount of time to figure out my Catalytic Converter had disintegrated and all the honeycomb stuff inside had plugged my exhaust system. I don't know that he hooked up a diag and checked for error codes, and I don't know if this is related to your error codes or problem.
I'm just tossing out my current issue because I've never had this happen before. The only way to know for sure is to take your exhaust apart and see if chunks come out.. which I am currently finding out is not such an easy thing to do ... at least not without destroying what you have.
Old 07-26-2009, 05:40 PM
frankyford's Avatar
frankyford
frankyford is offline
Dude I'm feeling your pain, I'm having the same problem with my 95 F-150 302 auto. I've been all over this sight trying to figure this out along with alot of other guys. I think I've narrowed mine down, but not sure.
Old 07-26-2009, 06:40 PM
Neptoess's Avatar
Neptoess
Neptoess is offline
the egr insufficient flow came up on mine when my vac reservoir(coffee can under hood on top of pass side wheel well) rusted a hole into it. Undo the little clip holding it down and inspect yours. The cat theory is also very plausible, as is a clogged fuel filter
