1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
4r100 vs. 4r75 transmissions
Old 07-24-2009, 05:08 PM
rocketman442's Avatar
rocketman442
rocketman442 is offline
I am replacing the 5.4L 2-valve engine in my '99 Super Duty 4x4 with a 5.4L 3-valve engine from an '06 E-350. I'll have the entire wiring harness, including every connector, from the van. My panic is whether the 4R100 trans in the pickup will have an issue with the programming of the 3V PCM from the '06 (which had a 4R75W trans - I also have that), or whether they are separately controlled. If the pickup was a 2-by, I wouldn't care about using the 4R75W and wire it all up using the van harness. But the 4R100 is almost 6 inches longer than the 4R75W and I have found no means of adapting the transfer case.
Old 07-24-2009, 05:16 PM
dkf's Avatar
dkf
dkf is offline
I would have thought the 06' E-350 would have the 5R110 (Torqueshift) trans in it?
Old 07-24-2009, 05:47 PM
DavidB's Avatar
DavidB
DavidB is offline
Behind a 5.4?
Old 07-24-2009, 05:52 PM
Tom's Avatar
Tom
Tom is offline
Wow, I just learned something today.
DavidB, in the SD trucks, they have been stuffing the 5R110 behind the 5.4 since 2005. So, it would logically follow that the same transmission in the SD trucks would be used in the SD vans.
But it's not.
As per THIS DOC the 5R110(TorqShift) was only put behind the diesel engine, all others were the 4R75E.
Very strange...
Old 07-24-2009, 06:00 PM
Mustang6147's Avatar
Mustang6147
Mustang6147 is offline
Thats not true...
The 06 is a torque shift...
Old 07-24-2009, 09:45 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
A computer that ran a 4R75 trans is not capable of running a 4R100. It won't work.
Old 07-24-2009, 09:58 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
But it's not.
Very strange...
That is strange but that document shows that the 4R75E was behind the 4.6 and 5.4 in the vans while the Torqshift was behind the 6.8 V10 gas and 6.0 diesel. And the Torqshift was behind all of the engines in the cutaway vans and stripped chassis.
Old 07-24-2009, 10:10 PM
Mustang6147
Maybe they had some left over 4R75e trannys that needed used up??
My girl has a 94 Z28 with an LT1 and a 6 speed man trans.3:73 posi. That package wasnt offered until 95 in T/A's and 96 in Z's It is an arguement everytime we order parts for it.
Old 07-24-2009, 10:16 PM
powerstroke72
That may be the case. I never kept up with the vans that much. It shows the 4R75E in the vans with the 4.6 and 5.4. I'm not sure why though other than your idea.
Old 07-24-2009, 10:20 PM
Mustang6147
In the late 70's in the G.M. line you could open any hood and find a random engine... Olds in Pontiac... Buik in Cadilac....ect... It was like cracker jack under the hood. Heck you might even get a 350 chevy that ran on diesel... God knows what they are thinkin
Old 07-24-2009, 10:22 PM
powerstroke72
I hear 'ya on that. I remember those days....it was a real hodge-podge.
Old 07-25-2009, 12:57 AM
Debbye51's Avatar
Debbye51
Debbye51 is offline
95 F350 crew cab diesel
Just bought this truck with 151K miles. Transmission shifts hard when going into passing gear. Does it need a pan service, adjustments done or what?
Thank you for your help.
Also noticed the steering seems looser than my old 97 F150, is that normal?
Old 07-25-2009, 01:10 AM
powerstroke72
Hello Debbye51 and welcome to FTE! You'll probably get some responses in here but will probably have better luck starting a thread of your own as it will probably get more hits and responses. Go to the top of the Super Duty/Heavy Duty forum and click on new thread. Then you can start your thread.
You may also want to start a thread here as well:
https://www.ford-trucks.com/forums/forum170/
^ ^ ^This is the 1994.5-1997 7.3 Powerstroke Diesel forum. Lots of knowledgeable folks down there as well that can point you in the right direction.
I'm not much of a transmission guy so I can't help you out much there but others in these forums can and will gladly help out. Best of luck with it and again, Welcome to FTE!
Old 07-25-2009, 01:55 AM
Debbye51's Avatar
Debbye51
Debbye51 is offline
My truck is a 7.3 International Diesel. 1995 F350 Crew Cab SD. Just got it today & it needs a few things. Couple of window motors, possibly an alignment. Just noticed driving it home the tranny shifts hard & the steering seems loose. Wondering if a trip to the tranny shop is needed or if a pan service will help it.
Old 07-25-2009, 11:22 AM
rocketman442
I thought so.. being that the 4R100 is an E4OD and the 4R75 is an AOD-derivative, is that correct? Do you have any suggestions as to my next step? Which one would be considered stronger? I grew up speaking "GM" and find myself in somewhat-unfamiliar territory with Ford electronics. Thank you in advance for your thoughts.
Brad
Quick Reply: 4r100 vs. 4r75 transmissions
