6.0 tranny cooler upgrade in a V10?
Hi all,
Just wondering if anyone has done the 6.0 tranny cooler upgrade for the V10. I know that a lot of 7.3 owners have done it, but haven't come across any that have done it for the V10.
Does the 6.0 cooler drop in to the V10 like it does for the 7.3 PSD and is the installation process about the same?
Thanks,
Brian
Thanks,
Brian
Replacement.
The 6.0L trans cooler is about the same size as the 7.3L's and the V10's put together.
For us 7.3 guys, it's a no-brainer upgrade for towing. For you V10 guys, if you tow heavy or a lot of mountains, it can help too.
Before the 6.0L's came out, the popular upgrade for us 7.3'ers was to use the V10 trans coolers as a replacement or in series along with our stock coolers.
There was a picture of the 6.0L trans cooler next to a 7.3L and V10 posted recently in the 7.3L forum. I'll see if I can find it and post it here.
Stewart
Stewart
They are both excellent trans coolers, and the difference between the two, cooling temp wise, was unmeasurable according to Mark Kovalsky.
Stewart
Thanks for the info everyone. I ended up ordering a True Cool tranny cooler. For $128 plus shipping, I got the same cooler as the stock V10 cooler that I have now plus all of the installation hardware that will let me hook it up in series with the existing cooler. Basically, I'll be able to double my cooling capacity for less $$ than installing the 6.0 cooler.
Thanks again.
Brian
Thanks again.
Brian
Thanks again.
Brian
Thanks again.
Brian
Stewart
Stewart,
To be honest, I don't know yet because I just ordered it. However, I did order the specific Superduty install kit with the cooler and since it is advertised as an add-on cooler to the stock unit, I hope the kit will provide me with some suggested mounting locations. That being said, if I had to, I'm sure I can find somewhere in front of the rad to mount the unit. I will let you know what happens.
Brian
Brian
Stewart,
Brian
Brian
This has the ingredients to be a great tutoring thread for others who may want to do the same mod, bro!
If you decide to put it in front of the rad, throw a gauge on your coolant to monitor before and after engine temps if you can! Loaded and unloaded temps on a grade, if possible.
Stewart
Take lots of pictures to document your experience!
Stewart
Stewart
Brian
Pele
05-27-2017 02:46 PM
jayjordon
11-19-2016 05:11 PM
BrokeLoser
15
10-30-2016 10:55 PM
Ezalycasaid
05-27-2016 08:27 PM
