Sponsored by: Real Truck
Sticky Cruise button?
Old Jul 19, 2009 | 05:46 PM
ReAX's Avatar
ReAX
Today something odd happened. I was driving along, turned Cruise on, hit set, rode along fine for about a second. Then the engine rev'd, dropped into 3rd and dropped again to 2nd before I tapped the brakes.
Hoping it was just a hiccup, I hit the Set button again and it down shifted and acceled again. This time I turned the cruise off with the switch. For another test, I turned cruise on. No effect. For giggles I hit the coast button. The speed set and stayed stable for 10 miles before I had to turn off. I tried it again coming home, cruise on and set, and it worked normally.
I'm half suspecting a sticky switch, as the speedo read correctly so the VSS is functioning. Unless it's a wiring problem in the column or a communication issue with the Cruise module. Anyone have any known issues, or a way to get some contact cleaner on the switches guts?
Old Jul 20, 2009 | 07:02 AM
F350-6's Avatar
F350-6
Only way to get to the switch guts is to pull the airbag. If you can find a good scanner you can run a switch test. That will let you know if it's a switch issue. I'd lean more toward a computer issue like the VSM not remembering what speed you're looking for.
Old Jul 20, 2009 | 11:34 AM
12ozd's Avatar
12ozd
I've heard of people cleaning the bottom of the switch pads with a pencil eraser. Never had to do it,might be worth a try.
Old Jul 20, 2009 | 05:01 PM
Furian's Avatar
Furian
You Keep What You Kill
I guess that you could use compressed air to clean out any debris in the CC buttons.
Old Jul 20, 2009 | 06:19 PM
F350-6's Avatar
F350-6
I don't think compressed air will work. The switches are contained in a plastic housing that has a back. You have to pry the casing apart to get to the switch guts. Now that I'm on my laptop I can add some pics & links.
How to remove the back cover off cruise control switch
Dirty & dusty but this one still worked fine
Switch guts :confused:
Bad picture of contacts inside switch
And last, here's a link on how to repair issues with the switches if they turn out to be your problem https://www.ford-trucks.com/forums/6...3l-diesel.html
Old Jul 20, 2009 | 06:26 PM
ReAX's Avatar
ReAX
Thanks. If it acts up again, I'll pull it a part. So far today no issues with it.
Old Jul 20, 2009 | 07:14 PM
F350-6's Avatar
F350-6
I still vote for the switch test. I pulled mine completely apart,checked and tested all things cruise button related I could think of with no luck. The switch test pointed me to the $27 CPP switch that took 5 min. to replace.
Know anyone close by with an AE?
Old Jul 21, 2009 | 08:20 AM
bobmiers's Avatar
bobmiers
Thanks for the photos... when I did my repair (BTW - still working OK) I didn't take photos. Bobmiers
johndem
Oct 13, 2024 10:09 PM
imacitybilly
Sep 3, 2014 03:27 PM
Evan_P
Feb 15, 2013 11:14 AM
Ourobos
13
Dec 2, 2012 12:10 PM
danskool
Oct 21, 2009 10:53 AM
