Cab Lights on the 6.7
BTW, these lights are federally mandated based on width. Tell the wife it has nothing to do with being "redneckish" and everything to do with safety. I in fact recommend adding a dually 3 light marker light right below the tailgate as well, as sometimes it can be useful in filling in that space between the tail light and grabbing even more attention. Remember, people are idiots, and a truck that size can easily kill somebody that is not paying attention. More lights is better.
The wife is an idiot. A Ford Super Duty is a wide vehicle. Having the clearance lights with your mirror marker lights at night or in poor visibility situations is a very good thing. It lets people know you are wider, it makes you stand out more.
What are you towing?
Some states require that the tow vehicle have ID lights if the trailer is wider than 80"
You could always just remove the bulbs when you don't want them on... but why have passive safety equipment that you physically disable? That'd be like removing the airbag module because you didn't like the way the steering wheel looked.
I am in WI. Most people tow their side by side sled trailers (101" width) with 1/2 tons. I have always used my Tundra or Yukon. They have no clearance markers. And most of the single rear axle HD trucks here don't have them either.
And I don't honestly think safety is going to be compromised if I don't have the cab lights on and I am driving around town empty and not towing anything.
I don't think they look redneckish, just wanna be a big rig look. I didn't really care for them, but my truck has them and they've grown on me.
As for your question, first look to see if they have their own fuse, if so cut split and run to a toggle. If not best I can tell you is to pull the headliner and follow the wires.
It all should be as simple as using a switch to disrupt the current. That's in my mind though so it could be a little more complicated.
Well I have mixed feelings on them. I think they detract from the clean lines of the truck. I will probably put the smoked lenses on them. But as I said, I want them for when I am driving through heavy snow up in the U.P. I want to be as visible as I can. I am sure they will grow on me too. Just never had a vehicle with them on it yet.
If you and the wife are inside the truck and they are on you will never know it!
For my 2010 the plug for the clearance light's was in the passenger side kick panel. Not sure where it will be on the 2011's, but i am sure if you found where they plug in, by following the wires like stated above you can easily splice them into a switch.
Kyle...
Kyle...
