Slowing down undercarriage rust!!!!
Roger
The zinc (galvanizing) sacrifices itself for the more "noble" iron, see it? :)
Even areas not covered by the zinc. You can see that action on certain
things, if you look close and now know the mechanism. :)
Pipelines use the concept and they call it "cathodic protection".
You can also see ships with the zinc blocks attached to the hull.
"adding stainless fasteners can worsen the corrosion situation" -Curly
Stainless containing large amounts of Chromium acts the opposite of zinc.
Not sure how any of that will help, but there is the theory anyway. ;)
I use motor oil on battery terminals and it has buffers in it but I believe
it mostly just seals out the air and so prevents the oxygen from reacting.
At work we had "NO-OX-ID" grease (with lots of buffering in it) and the
motor oil worked -better- IME because I believe the specilized grease
was too thick and didn't coat as good as the motor oil.
At first was just thinning the NO-OX-ID grease with motor oil for "cold;)"
weather use and found out it worked better thinned out with motor oil
so just kept at it expecting to get it too thinned out and stop working.
Figured I'd just go back to the mixture that worked best and call it good.
Well, eventually tried straight motor oil with top-notch results. {shrug}
So the idea of motor oil, ATF, diesel fuel etc all sounds like a good idea
to me. :) Edison battery company sold bottles of oil to put on battery
terminals and supplied some with all their new batteries. It was thin and
clear and and non drying and some said it was vegetable oil.
Edison batteries had sodium and/or potassium hydroxide in them.
And the older batteries I worked with had a metal case, no plastic.
They were high maintenance. ;)
I found the motor oil to work better than their oil on all the different
types of batteries I was maintaining...
nickel/iron
nickel/cadmium
zinc/air
"lead acid" (lead/lead oxide with sulfuric acid)
Alvin in the un-rusty southwest :)
And retired railroad signal battery janitor. :)
ps- http://www.antiquebottles.com/edison/
Heck, I can tell that wasn't written by a railroad signalape because
there were -way- more signals (and batteries) used for train control
than road crossing signals, even downtown.
Cool, I have one of these I kicked out of the dirt while "rollin' a train by"
during the late 70's at the crossovers at Draggon AZ...
Bloomfield 2+1/2oz Oval-Flask Cork
http://www.antiquebottles.com/edison/codes.html
My 18 year old 92 still has the factory wax coating on it-and no frame rust at all.I can dug my fingernail into the wax on the frame. But then-I live in Colorado that usually has single digit humidity. The only undercarriage rust is on the parts not coated in wax- the front and rear spring hangers.radius arm supports-ect. And this is just surface rust-the rust got under the factory paint and corroded from underneath.
Apparently the factory wax and paint coating doesnt stop frame rust in the rust belt.
What happened to your frame wax up there in the rust belt?? Does the salt eat away at the frame wax??
Hey phoneman91, when I removed my back bumper, I had a big pile of RUST from the bumper brackets, you could just scrap it off with your fingers. haha. brackets were down to about half the thickness of the new ones I put back on!
I too wanted to protect/preserve my truck, I had the bed off sanded the frame with body grinder w/ wire wheel. I used a product called Chassis Saver. I think any of the under car coatings are good. They just need to be applied. I did all the way up to the front. I just used car ramps for under cab and removed front wheels and sanded everything I could, with small wire brush and scraper for hard to reach places. I did the bottom of the cab too. Did everything I could. It's mostly a labor job.
and a messy job..
and a messy job..
The neat thing about Ford is that FOMOCO are still making parts for our trucks!! I bought a brand new spare tire carrier that was made just 4 months earlier. I also bought a brand new front grill that was made just several months earlier. And a new radiator!! (I dont want to place Chinese parts on my American pickemup!)
After a snow storm-I take the truck to a coin wash and lay on the ground and spray overhead on the bottom of the truck with high pressure water. Especially in the fenders. Colorado is nice in the sense that it can become 60 degrees after a major snow storm and allows one to clean their truck of salt.
What is that Chassis Saver?? Is it a paint or a surface conditioner?? Got any pictures of your undercarriage after the application?
just google it and read... there are other products, that's just what was here locally at auto body store. It's like paint, pictures?
just check my gallery and see my project from the spring... I painted everything with it, even the gas tanks.. suppose to be good stuff but OMG it is messy.
