How to change/fill my zf5 trans
Here's How:
1) Drain fluid by pulling the drain plug (the lowest plug)
2) When it is done draining, replace the drain plug and remove the fill plug (the higher plug), And use a hand pump or suction gun to put the oil in. Pump oil in until it starts to trickle out of the Fill hole.
3) Replace the fill plug.
As for fluid, Ford Specifies Mercon ATF for the ZF. I use Chevron MD3 in everything I have that uses ATF.
The following users liked this post:
abyars111
04-16-2013 05:36 PM
krumpelsaurusrex
07-01-2009 03:27 AM
