Econoline cluster for the copper truck
So the copper truck, 77 F350, had a gauge cluster with the composite back that turns to dust. I had fixed it several times, but finally decided to replace it. The best replacement I found was from an 80s Econoline on eBay. So that's what I got...
The cluster came with the Econoline bezel...
But the back was standard for our trucks
The bezel was attached by 1/4" hex head screws
And came right off
after preparing the new cluster, I set about removing the old cluster...
And came right off
Pulled the screws from the bezel
Bezel out, remove the screws from the cluster
Cluster ready to pull
The hole left behind
The speedo cable and the harness
Then it was time to install the new cluster...
Fits like the old one
Speedo and harness connected
Screws in
At first, the right turn signal didn't work, nor did the headlamp/washer bulb, so off to O'Reilly...
Replaced the illumination lamps with LEDs
Bezel back on
Now the gas gauge doesn't work, but it's getting late and I'm tired
Econoline cluster update
Got the fuel gauge working!
First thing I did was ohm out the sender unit. Tank is full, and read about 12 ohms across the terminals. Tested the sender to chassis ground, and that was good, too
opened up the dash and pulled out the harness for the tank selector. The green line was showing infinite resistance to ground-an open circuit
Couldn't find a wiring diagram for a 77, but other years are supposed to have a 8 pin plug at the firewall. Couldn't find that, so I ran a test line from the sender to the selector harness. Gauge then read full. So I routed and secured the new line and put the dash back together. Done.
Everything works!
Drove around just to watch the gas gauge go down. Coming up the hill, a ricer tried to pass, so I tested the kickdown. It works!
Everything works!
Save the cut off wiring plug that was in the back of your new cluster. Find the wire that is for the ground, strip an inch or so, & mark it. Figure out what wires go to all the lights, strip the wires back & twist them all together. Now you can plug it in to the back of a cluster, hook the ground to a battery charger ground, red to the lights wire, & test all the lights before you install a cluster in a truck. Lots easier to test, clean & replace bulbs with the cluster out of the truck!
86f250hd
12-16-2013 10:10 PM
Marky48170
Ford Truck Parts for Sale
01-11-2012 03:59 AM
John311t
23
07-10-2008 10:29 AM
