Smokey part throttle
Okay here it goes well for some reason my truck smokes quite a bit at part throttle no matter what setting my chip is on except stock. The only way to get it to clear up is floor it get get the turbo screaming or make it shift down.
A example cruising 70 down the highway come to a hill or give it a little gas to change lanes look in the mirror and you can see smoke
I know this is killing mpg and need to fix it. No IC pipe leaks everything looks fine I am at a lose
Mods: Zoodad, AFE st1, CCV mod, Van turbo, WW, 6.0 IC, IAH delete, 140v IDM, Diesel Site flip chip, Deleted EBPV, Shimmed FPR, Hutch, HPX, 3.5" straight pipe
on
I see a little more smoke ''down low'' since I put the 38R on my truck. It puffs quite a bit more since my upgrade injector install last weekend. I don't really like to see smoke in my daily driving, but it is something I'll have to get used to. Live tuning should help in this area. I also see a little more smoke due to the warmer, less dense air in the summer here.
on
How long have you had this turbo, or is this problem new to your truck?
