Arm rest removal
Old Jul 9, 2009 | 05:47 PM
Piercepierce69's Avatar
Piercepierce69
Arm rest removal
Ok, I have a 1995 Ford Ranger extended cab. I want to remove the arm rest to get it redone. I have tried to remove it but cant figure out how. Can anybody give me any advice? Thanks.r
Old Jul 9, 2009 | 08:48 PM
Rockledge's Avatar
Rockledge
If your '95 center console is like a '98, then look for access panels on each side of the armrest console, at the upper rear. Pop out the panels and you'll see some bolts that you'll need to remove.
Old Jul 10, 2009 | 07:48 PM
michigan66's Avatar
michigan66
On the other hand, if your arm rest is like the one on my '91, unzip the cover and you will find a hole in the foam on the passenger side, toward the back. If I recall correctly, there is a torx screw way inside. Unscrew it and you should be able to remove the arm rest.
t-rex_toyota
Jul 17, 2017 08:58 PM
jersdungeon
Aug 15, 2015 09:05 AM
JWA
May 24, 2012 05:38 AM
Bert3686
Nov 19, 2008 07:24 AM
55-willys
Jul 12, 2003 02:28 PM
