2001 F150 4.2 Detonation
The valves in my 4.2 have been rattling like crazy w/ an empty truck and just barely having the throttle cracked goin down the interstate and approaching a mild grade. It has 142k and has good low end but looses some power shortly after. Also, when cruizin down the hwy, it feels like it will drop 2-3 cyl's all at once for a split second. It does that pretty often. The other symptom is on startup. Its not smooth. It lights right off no problem but sounds like it's detonating on startup as well. I've got intake upper/lower but i think i'm gonna just try intstalling the plenum gaskets first to see if that cures it. I'm assuming this is all from a vacuum leak. I saw what appears to be a light dust trail on the inside lower half of the plenum when i split it but then again that could have shook off during disassembly. Any other ideas that might help? I know the 3.8/4.2's are trash but I'm tryin to milk this one as it was a freeby. I've splent plenty of hours working on both tryin to repair head gasket failures. This is def some of fords worser engineering.
Im not sure why you think the 4.2 is such a horrible engine??? They have proved very reliable with the exception of the 97-98 intake manifold gasket issues?
As for your loss of power I think your on the right track with the vac leak... this is something you culd have checked before tearing it down though. It would have been a big help to check that first instead of tearing into it without a clue what your looking for. To the rest of you reading this dnt just jump into exploratory surgery on your truck because you have some power loss ask some questions and try to diagnose the problem before tearing your engine apart and bitchin about the motor because you dont know how it works or how to fix it
On My 4.2 I replaced My Cam Position Mod. yesterday. The truck has been running ruff with no power. It seemed to help, but still not as good as when I bought it. I was impressed with the 4.2 until it started to miss and lost power. Now I'm stopping in to A-zone about once a week and having them do a CEL test. Every time it's something different.
Im50fast
Modular V10 (6.8l)
10-11-2015 07:44 AM
v8only
43
05-03-2007 02:54 PM
