95 F150 Won't Crank. Please Help!
The ign switch is mounted on the steering column under the dash. You can loosen the bolts holding it and move it a little down the column in case the key switch is not operating it properly.
However if you look on the fender mounted relay there is a light gauge wire (can`t remember the color) with a push on connector, pull this off. Now get a length of wire and jump from the positive battery post to that terminal on the relay. If the starter does not crank then the relay is bad and needs replaced. If it does crank then you need to adjust the ign switch or maybe replace it.
I tested the relay as you said and it worked. I don't see any adjustment in the ignition switch, but I did notice that when trying to start the truck and turning the key all the way forward, the odometer blinks out and the speedometer needle moves as if there is power going somewhere? That leads me to believe the ignition switch is working? I'm not sure though.
The next thing you should do is pull the light gauge wire again at the fender mounted relay and put either a test light or a voltmeter between it (the wire) and ground and get someone to turn the key switch to "start". The light should light or the meter should show 12V. If not then the ign switch is bad or out of adjustment.
It should be possible to loosen the screws holding the ign switch to the steering column (under the instrument cluster) and move it up or down the column.
Cbartlett1988
17
01-02-2016 10:29 PM
CDaddy
10-10-2010 08:17 AM
AdamJo17
31
11-04-2008 01:01 PM
