Anyone here use the x-fer case PTO?
My old white OBS had one (1994.5) and I thought the manual said it was and option for 1-ton truck x-fer cases but I lost the manual a while ago.
My current OBS doesn't have one...unfortunately (or I just missed it...it is pretty dark outside)
on edit:
the old truck was a manual and this is an auto if that has any effect on the option list from ford
on edit:
on
I don't use one but I do have a t-case with PTO option out of my parts trucks. I have no use for it really. I have thought about it but came up with nothing. If you have a manual trans you always have the PTO option but with an auto you need a PTO t-case. The biggest issue is that the exhaust will usually be in the way. BTW my PTO t-case is for sale if anyone is interest!
on
No its a 1356 out of a 95. It is from a 350 regular cab with slip joint rear output and double cardan Front output yoke. I have thought about selling it to a D60 conversion person but for now I want to keep it whole.
on
1 Post
The PTO gear meshes all the time, and the clutch to turn the PTO on and off is in the add on part of the PTO. It's a dog clutch so things have to be stopped for it to engage.
With a stick: you put the clutch in, put the x-fer case in neutral and then engage the PTO. You can run the PTO at different speeds by shifting the transmission.
With an auto it's a little more complicated. You need a PTO controller that will lock the torque converter and force the transmission into the gear you select. Without the controller, the transmission would stay in first because shifts are based on the VSS on the rear and, and if you're sitting still the PCM will just stay in first. The controller also includes a idle speed control that will regulate the RPM at a desired point. An auto does have one pain in the butt feature: In neutral there still is a bit of a drag. If you have a direct drive device like a winch, this amount of drag can hang up the PTO clutch and the only way you can get it to disengage is to kill the engine.
on
IMO it would be easier to run it off the belt in the engine compartment. If you didn't see my thread about my OBA project search "on board air" under my user name
on
With the PTO either way (auto or ZF trans) there are major room issues on a 4wd. Either the exhaust or the front driveshaft is in the way for a PTO unit. It would be pretty tricky to get it to work.
