Im gonna light it on fire
  #31
Old 07-31-2009, 04:54 PM
BigSix1
BigSix1 is offline
BigSix1 is gaining momentum as a positive member of FTE.BigSix1 is gaining momentum as a positive member of FTE.
Originally Posted by Alvin in AZ View Post
Yeah but.
Since it's got an automatic transmission in it, heck, it doesn't matter
if it's working or not, it's just junk, and might as well be lit on fire. :/
Just my humble and sorry-assed opinion.
YMMV?
Alvin in AZ
Alvin,
You said what I was thinking, but in a lot less words--I admire that.
Some may score you less charitably on a perceived lack of...diplomacy, shall we say?
But again, there's value in being concise--I could learn from you, Dude! LOL.
And the OP clearly has mad skills (since he can work on automatics--yikes!)--he could do the swap, so I'm sure he'll understand we meant well.
Big Six
  #32
Old 07-31-2009, 05:21 PM
Alvin in AZ's Avatar
Alvin in AZ
Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
Originally Posted by Roark View Post
I really dont like auto's either. I would like to swap to a manual but I dont
know wich one I would switch to. A ZF is too HD for my application I think.
It would seem like overkill to have that trans. in a 2WD SWB F150. I would
think about a M5OD, but Ive heard they dont like tourqe, and my 351 puts
out somewhere around 400ft.lbs.
My plan is to put a ZF in a '91 Bronco.
I'm dumber than you thought, huh? ;)
The most important part, of course, is getting rid of the E4OD.
The second important part is getting a wide ratio transmission so
I can skip first gear like I do in my '75 F150 with a 360FE + T18. :)
And third want an overdrive, because I got spoiled by that part
of the E4OD in my '91 F150. LOL :)
An F250 parts truck is the cheapest way to go for me, because
of all the other crazy stuff that goes with a swap like that.
The Mazda seems to be strong enough, but it's a "car like" close
ratio transmission and so I'm not interested in those at all. With
your hopped-up engine you might be better off with the Mazda? :)
On another website forum there's a transmission rebuilder that
prefers the close ratio Mazda to the wide ratio ZF for a few
(several?) reasons. PM me if you want to know where he hangs
out?
Alvin in AZ
  #33
Old 07-31-2009, 05:29 PM
Roark
Roark is offline
Roark is starting off with a positive reputation.
I think Id rather see the transmission bounce off some rocks on its way down a bluff and eventually splash into Skiatook lake. BTW I have absolutely no skill or experience with auto's, so thats probobly why Im in this predicament
  #34
Old 07-31-2009, 05:31 PM
Alvin in AZ
Originally Posted by BigSix1 View Post
Alvin,
Big Six
Cool, Thanks. :)
I'm just trying to have fun. :)
Alvin in AZ
  #35
Old 08-01-2009, 03:12 PM
Roark
Roark is offline
I adjusted the band, checked the modulator(good), and tightened up the lines again. I took it for a drive, and it still wont shift from first to second. I can get it to shift through the gears manually, but only under low load. It will start slipping if I get on it at all. I think I got bent over on this one. Thanks for the help.
  #36
Old 08-02-2009, 07:41 PM
Neptoess
Neptoess is offline
Neptoess is starting off with a positive reputation.
craigslist at work lol
  #37
Old 08-21-2009, 06:56 AM
Roark
Roark is offline
Well I went with an AOD. I had a local trans. shop rebuild one with HD componets, and a B&M transpak. I got the trans in, and bolted up. Now, I just need to find a driveshaft, and make some new lines. It seemed like everything was easier installing the AOD over the C6. Maybe It was because I took my time, but it was easy. Cant wait to get it back in action. Thanks for the help.
ralbery
11-18-2014 11:26 PM
davidh11
1999 to 2016 Super Duty
09-02-2014 09:05 AM
ReFlectiveMan
01-20-2012 09:44 AM
justanotherjoke
12-08-2006 09:50 PM
gov2mod
1978 - 1996 Big Bronco
01-12-2005 02:09 PM
Quick Reply: Im gonna light it on fire
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
