97 E4OD problem
Old Jul 8, 2009 | 11:15 AM
jatatkupak's Avatar
jatatkupak
97 E4OD problem
I have a 97 f-350 with 7.3 power stroke 4x4, it has a E4OD trans.
It shifts ok most of the time but when cruising at 55 mph the engine runs at 2200 rpm, sometimes it shifts fine and it runs at 1800 rpm at 55. Sometimes seems to double shift at the third step. I can toggele it in and out of overdrive with push button and trans. shifts down and up like it should, increasing the engine rpms by about 600 to 700 rpm.
Has anyone seen this problem, or offer any insight to what the trouble may be.
Thanks
JT
Old Jul 8, 2009 | 11:21 AM
Brown Falcon's Avatar
Brown Falcon
could be the torque converter...
Old Jul 8, 2009 | 11:13 PM
oldbird1965's Avatar
oldbird1965
I'm wondering, like Falcon, if your TC is slipping. Doing the TC switch mod would tell you if its slipping. Its a easy mod of spliceing into one wire back at the trans and putting a toggle switch in the cab. You could lock your TC to see if its in 4th gear or slipping in 3rd gear.
Old Jul 8, 2009 | 11:17 PM
maverick1701's Avatar
maverick1701
the problem is that you have a stock e4od under your truck ... unfortunately I have the same problem
Old Jul 8, 2009 | 11:40 PM
JethroF250's Avatar
JethroF250
same here. think she will hold up for one more sled pull in 4 low? opinions please cause i experience the same problem as JT every now and then
Old Jul 11, 2009 | 04:22 PM
IDMooseMan's Avatar
IDMooseMan
I have my truck back in the shop because of this. I had a new tranny, TC and flexplate installed at the dealer late last year. Since then, the dealer had to replace the "new" TC and front pump.
I'm beginning to think I should've spent the money on swapping in a handshaker.
If this doesn't get resolved soon, I'm gonna setup an appointment with dealership owner.
I wonder if a bad CPS, ICP or VSS could cause these problems.
Old Jul 11, 2009 | 05:19 PM
DRRXR's Avatar
DRRXR
I would PM MADVAN. This is right up his ally.
https://www.ford-trucks.com/forums/member.php?u=170631
Old Jul 11, 2009 | 10:01 PM
Bronk351's Avatar
Bronk351
I have this same problem in my new truck as well.. I had it into the trans shop already and they said it was a bad TPS.. I swapped them and still same old crap goin on... I just keep disconnecting my battery to take it out of limp mode, Shifts fine when the light is not flashing but once it starts it shifts real hard taking off...
Old Jul 11, 2009 | 10:15 PM
c00nhunterjoe's Avatar
c00nhunterjoe
if the light flashes then it has codes stored. most of the time it is a slipping torque converter clutch
Old Jul 12, 2009 | 08:13 AM
MADVAN's Avatar
MADVAN
X2 on joe.
OP
Sounds to be tc related.
Does your cruise control work?
Check it first.
Bill
Old Jul 12, 2009 | 03:09 PM
IDMooseMan's Avatar
IDMooseMan
My cruise control does work, most of the time. Sometimes it shuts off / deactivates for no reason. I'll have it set at a certain speed; the truck "kicks" a little and the cruise control is deactivated (like you stepped on the brakes); I press "Resume" and she accelerates to the previous speed setting.
Other times, she'll kick out of cruise and not want to "Resume" no matter what I do, so I use my right foot and set the cruise control again.
Edit: (From a previous post) - I wonder if a bad CPS, ICP or VSS could cause these problems.
njtinman2
13
Nov 22, 2015 06:12 AM
soupcancowboy
Aug 16, 2015 04:56 PM
TheGuyOverThere
Jun 9, 2014 08:30 PM
screaminford
Jan 24, 2011 09:29 AM
