Limp mode??
Limp mode??
Heres the question how do i know when my truck is in limp mode? what are the symptoms??
The scoop i had arp studs done about a year ago as well as egr delete kit from liborator with egr valve still in place plugged in with sct xcal2 eric inovv.tuned. when i got the truck back from shop after all was put on my truck only saw 15-22psi of boost with cel througing 2 codes both egr related. bought the xcal 2 and the 2 codes cleared and bypassed through the tunes. truck still only saw about 22 psi max boost with agg. street tune. NOTE: boost in this tune very slow to spool up and tons i mean tons of black smoke when punched from a dead stop. So i bought a bd Boost builder and now my dashawk gauge jumps from 5 psi to 17psi goes to 29psi. it doesnt gradually go up lik56789 10... ect. has anyone else seen this/experiance this problem with the same things done on a 07. also my original ? how do i know if it is in limp mode.
mine didnt come with a block off plate b/c i tink i bought a earlier version and they didnt offer/come with one. also if i do block it off and unplug the egr the CEL will come on. Ran a little test just now took off the bd boost builder and in street economy tune my truck boosts to 22psi and goes back down to 18. in stock mode with bdbooster unplugged goes to 18 and creaps to 20 but no more than that. is this a symptom of limp mode??
maxium you are right. the CEL only comes on when i dissconnect the egr valve. when i plug it back in its fine. IE. i am curently in stock mode with the egr valve plugged in and no CEL. i am running a couple tests i just put my truck into stock mode with the bd boost builder/fooler plugged in and boost goes to 24 and comes back down. gonna leave it in this mode for a highway run when i get a chance and see what happens. when im done with this test im gonna put innovative agg. street tune with bd boost builder and without boost builder and see what i get for boost #'s will keep you all updated but in the meantime any input?
no i didn't have a tuner b4 the delete. the reason for me buying one was i figured my truck went to the so called limp mode due to insufficient flow from the EGR valve. i had EGR codes P0404 & P0405. so i picked up a new X3 from innovative to pull the EGR out of the computer. i don't have the codes anymore, however i still only boost 22 or so max.
spool is a little faster then it was stock and before the delete. if i roll on the throttle (which is the best way with these trucks) it spools great and sends the truck sideways . i am runnin on stock head bolts so the lower boost doesn't bother me so much. i am thinking i have a leak somewhere. my IC boots on the hot side are not in the best shape. so, i plan to replace them and a few other items.
I would say u have a leak or maybe the vanes in the turbo... if you haven't already checked the turbo. I was running probably 25 lbs of boost before i did the egr delete then it went up to 28 and wouldn't pass that which is what i was happy with seeing as i don't have studs either. Now i've got an x3 from innovative and i can see over 32 lbs in no time. I like it and i hate it... there's barely any lag but not having studs worries me. I don't know but leaks and vanes are something to check on.
scameron what do you mean they are not in best shape?? they look cracked or they have a lot of oil on them??
shawn what tune do you have from eric. i have xtreme street and when i punch the throttle all i get is alot alot of smoke and after about a few seconds the truck spools up and goes. in none of my tunes that i have do my trucks tires spin when i punch the throttle from a dead stop. how do i know if my vanes are stuck??
let me know if this works and what you come up with. in mean time i am gonna have to check to see if my boots are cracked too should i tke them off to look?? when i had my stuff done last year a ford diesel tech did it and i am sure he would of told me if they were cracked also i have a new turbo as of a year ago
