Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
code question
Old Jul 7, 2009 | 12:17 PM
ballbandit's Avatar
ballbandit
code question
I have 03 escape and the computer says it has the code p0136 ho2s 12 sens.lean. any ideas which o2 sensor is bad. i have found three of them.
Old Jul 7, 2009 | 12:44 PM
budwich's Avatar
budwich
I don't believe that code indicates a "bad" o2 sensor. More than likely its indicating a leaky intake condition.
Old Jul 7, 2009 | 02:02 PM
wptski's Avatar
wptski
That's Bank #1 Sensor #2 or the second one on the front bank but it's not always the sensor.
Old Jul 8, 2009 | 10:49 AM
ballbandit's Avatar
ballbandit
if it is not the sensor any ideas? is there any way to check the sensor with a multi meter or anything else? thanks
Old Jul 11, 2009 | 09:36 PM
budwich's Avatar
budwich
"forgive" my first post as it was a "first guess" and only partially correct. The part about the "usually not a o2 issue" is correct (imo) BUT based on the clarification being the "secondary sensor", it is likely it is pointing at a leak in the "outtake" / exhaust area in front of "said sensor".
Old Jul 11, 2009 | 10:32 PM
wptski's Avatar
wptski
Not in this case. A special DMM like a OTC DAT has a O2 test function.
You could see if you can force it to go rich by opening a propane torch in front of the intake. You should get a rich DTC on both banks then.
mike L
General Automotive Discussion
Jan 22, 2013 10:47 AM
2valvekid
1983 - 2012 Ranger & B-Series
Dec 29, 2005 03:53 PM
y2kexc
18
Jul 29, 2005 08:04 PM
jbm
1997 - 2003 F150
May 20, 2004 08:48 PM
