Fix it and make it more reliable.
Hello everyone!
This is my first post here. I have read a lot of the posts, on this site, and after hearing all the problems that people have, I feel somewhat fortunate.
I have had my 2005 F350 CC for 3 years now. I bought it second hand with 40,000 miles, on it. I now have 75,000. I use it to pull my 36ft gooseneck race trailer about 4 times a year and my open car trailer fequently. I also use the truck as my daily driver.
Within 1 month of purchase I bought a Banks Power Pack kit and installed it. I was hoping for better MPG. I got maybe 1 mpg on average but the power increase was incredible.
Until recently I have had little trouble (1 dead battery and a clogged fuel filter). Last week when I took the 36ft to Carlisle (50 mile trip) It over heated and puked severly. When it cooled, in the morning, it took 3 gallons of coolant to refill it. There was still a lot of pressure, in the system, when I took the cap off. I read that this is a good indication that the head gaskets are not blown. Is this correct?
I have used the truck, to go to work, all week and it is not overheating but the coolant is still slowly disappearing.
According to all the info that I have gathered from other posts, it must be a problem with that EGR cooler. I am looking at upgrading or deleting it. I woud realy like to delete it but I am concerned about getting hit during Pa. state inspection. I think that the stations here are supposed to do a visual to see that the factory emission equipment is intact. Have any of you ever had trouble getting an EGR delete through an inspection?
I always do my own work so I am getting ready to do EGR and maybe head studs. I really want to get it done so that I can make a car show in Ohio in August.
A few questions that keep coming to mind are:
What are the steps that are required to lift the cab off? Would it be easier to pull the engine out of the compartment?
Where can I find all the torque specs?
Do I need any special tools?
If I do this work, I will try to take some pictures and share the results.
Thanks to all of you.
if u are loosing coolant it's leaking down thru a bad egr cooler..do a EGR delete..
i did one on my 2005...you DO NOT HAVE TO TAKE THE CAB off..
It takes about 12 hrs to do one..you have to remove the trubo and turbo mount and a few big hoses connected to it..this is how i worked on my truck..
EGR Cooler:
Old UP Ppie:
Old EGR Valve:
ALL GONE..I went with River City Diesels EGR delete kit...truck runs soo much nicer now! I also put a 4inch Magnaflow exhaust turbo back on with no cat at the same time.
The work isnt that hard to do..just time consuming. To put new up pipe in i took out the right inner plastic fender and it's a straight shot to it. It's a lot easier if the pipe comming down off the turbo isnt there (why i did the 4inch turbo back at the same time ..gives ya more room to work with it off).
EGR Cooler:
Old UP Ppie:
Old EGR Valve:
Personally from what I have been reading I think I would go with the Neil Ind. upgrade. It is much stouter looking than the stock unit and living in Ca. they change inspection requirements like most people change underwear therefore you never know what the rules will be tomorrow. with the carcon cap legislature and everything else happening I only want to do it once. And don't forget ramifications if you have any warranty left.
Thanks for the help..Help I like the scafold Good idea. This is the highest engine bay I ever had to work on. I asked about the cab off procedure because I am thinking about doing the ARP head studs. If work on the Egr cooler solves the immediate problem, the studs can wait.
I am still torn about delete or upgrade. The hot rodder in me is screaming delete but as 69CJ stated you never know what they will require next, for inspection.
I guess, if it only takes 12 hours and I save the old parts, then I could relatively easily go back and do the upgrade, if I had to.
on
If you're concerned with passing emissions, especially visual, just do the bypass.
By the way, dump the Banks and get something that truly programs the truck's ECM and TCM especially. Banks products tune neither.
I agree with Shawn, My 04 has never had a problem and I'm a pretty fair mechanic but I can see 12 hours before I see 4. Maybe it's the way I clean everything. Actually I hope to never do the job but I can see how much better the aftermarket parts are. Maybe because I'm 65 now..........Good luck
on
Bean can do it quicker, but he also knows a little more "tricks" then just someone like us DIYers.
I hear ya cart. I'm pretty **** about doing things too. Do it right the first time and be done with it. 4 hours is just amazing to me.... i'm not trying to be a smart a#$ but man that's really moving.
