Important video/info on Cavitation
Old 07-04-2009, 11:06 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
I made a youtube video brieflly explaining what is, and how to prevent Cavitation in any high compression engine.
Link:
http://www.youtube.com/watch?v=KUvRy...e=channel_page
If you know anyone else with a diesel and does not know about this, please send this video to him/her. All the info you need to know about Cavitation are in the video Discription.
Old 07-05-2009, 07:41 AM
ljutic ss's Avatar
ljutic ss
ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
Were you caught by surprise when you opened the radiator cap, or was it known the tank was down?
Old 07-05-2009, 11:36 AM
IDIDieselJohn
No haha, it's been a little low like that for close to a year.
Old 07-05-2009, 12:57 PM
David85's Avatar
David85
David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
Brave words lol.
Old 07-05-2009, 06:19 PM
F250FarmBoy's Avatar
F250FarmBoy
F250FarmBoy is offline
F250FarmBoy is starting off with a positive reputation.
Nice video! I like the 15 year old learning to drive also.
I like the one on OBN's Tech articles as well. It shows an actual view of inside the cylinder walls and you can actually see water drip out of nowhere! And it has a nice animation of the explanation of cavitation.
http://www.oilburners.net/articles/cavitationartic.html
Old 08-05-2009, 04:25 PM
Vince dEon
Vince dEon is offline
Vince dEon is starting off with a positive reputation.
The video is quite clear and shows how to determine if you have enough additive in your coolant. But how do you test for cavitation itself, short of tearing the engine apart?
Old 08-05-2009, 05:41 PM
F250FarmBoy
You cant, even if the engine is tore apart. There's no way to measure cylinder wall thickness. If you dont have the symptoms of cavitation, then its not too late to start adding additives and such. Cavitation is not reversible, but it is stoppable.
Old 08-05-2009, 09:39 PM
johnboggs21's Avatar
johnboggs21
johnboggs21 is offline
johnboggs21 is starting off with a positive reputation.
I saw that video before John. I like how it makes things pretty clear for the average joe.lol I need to get some strips and test mine sometime soon too.
Old 08-05-2009, 10:08 PM
archangel
archangel is offline
archangel is starting off with a positive reputation.
This guy does not know what he is talking about!!!
He is either blind or a complete knucklehead.
The basics on cavitation he got right, but what the heck is he talking about rpm's and running the engine for?
It's the amount of additive in the coolant and it does not matter if the engine is running or not.
It's a test that needs a specific temp (between 50 and 130 degrees) and timed for between 45 and 75 seconds!
PPM is not the same as RPM, and it states 0 PPM, 300 PPM, 800 PPM, 1800 PPM and 3200 PPM, as in PARTS PER MILLION!
archangel
Also, there is a thing they can do called sonic checking the block and it will measure the remaining thickness of the cylinder wall.
Old 08-05-2009, 10:17 PM
1994diesel's Avatar
1994diesel
1994diesel is offline
1994diesel is starting off with a positive reputation.
Wow, archangel, wtf is with insults?
Good vid John.
Old 08-06-2009, 11:16 AM
IDIDieselJohn
Good vid John.
No haha hes right, I did do a mistake.
Old 08-06-2009, 11:19 AM
IDIDieselJohn
Thanks for pointing out my mistake! I didn't pay attention to bottle I guess, I will corect that. Anyway, I only made this video to try and get the word out, this is nothing pro!!
Old 08-06-2009, 12:07 PM
luthrobediesel's Avatar
luthrobediesel
luthrobediesel is offline
luthrobediesel is starting off with a positive reputation.
Good job with the video. RPM PPM same difference lol.
Old 08-06-2009, 03:50 PM
fuzzy1626's Avatar
fuzzy1626
fuzzy1626 is offline
fuzzy1626 has a good reputation on FTE.fuzzy1626 has a good reputation on FTE.
Better check the date on those strips. When the third pad (nitrate) is brown they are NO GOOD. Unless you own a fleet of trucks it's better to buy the four pack of strips that are individually sealed.
Quick Reply: Important video/info on Cavitation
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
