Big trucks need loud horns!
Hi Guys
Or to put it another way - Yet another Hadley air horn installation.
First up made a mounting bracket for the horns.......
...to mount them on the frame.
Then another bracket to mount the air tank, wiring....
....and compressor.
Finally fitted an illuminated switch to change from OEM horns to the Hadleys. This switch illuminates dimly with the parking lights and brighter when switched to the Hadleys.
Just incase anyone is interested in fitting some here is my wiring diagram.
Now off to provoke bowel movements in old ladies
Regards
Dereck
....and compressor.
Regards
Dereck
on
Nice set-up... Look familiar!
Nice job with the installation of your Hadleys!!!
Your horn mounting spot and fabrication look alot like mine...
Prior to your install did you see my set up here on FTE?
-OR-
Do great minds think alike?
In case anyone wants to see my set-up or "searched" their way to this post, here's a link to how I installed mine (you can never have too much info!):
Hadley Air Horns Installed!!!! Pics Too!! - Ford Truck Enthusiasts Forums
One more thing... I like where you mounted your compressor. I had to replace mine after 1 year... here's a quote from a previous post I made regarding the compressor:
Once again... Grrreat set-up!!! (Reps given too).
-OR-
...you are using a VIAIR 380C compressor... I replaced my original Hadley compressor with the 380C... That is a great compressor! I have it mounted in the same spot as the old one (you can see in the pic). BUT... I ran the inlet for the compressor into the X's cabin.
My old one failed due to it's inlet had only a small filter that was open to the elements... The 380C has the option of using tubing to remotely mount the inlet filter.
I did see you set up here on FTE and let's say I drew inspiration from it
Many thanks for the compliments
Dereck
I have a single grover on my truck, with 2 - 1 gallon air tanks, and an old junkyard sourced firestone air suspension pump to fill em. Setup with truck air brake hose and fittings. Works great and mucho cheapo and plenty loud! Guy on another board I'm on actually built it, I got the setup for $200. The tanks and pump are mounted to a board I just keep in the back of my truck in the passenger cabin, pump rarely cycles unless I'm laying into the horn so it doesn't bother me having it back there.
Not sure on the exact model #, but the horn I'm running is one of these, dealer said it was the deepest tone they made in that style. 1700 series trombone. http://www.airhorns.com/products.aspx?category=truck
Does anyone have a normal schematic?
I'm trying to hotwire a used kit i just picked up and i don't understand how to hook up the horn switch.
Also, i have the power going to the top switch on the compressor, coming off of that to the pump. There are 2 leads on that switch, does it matter which wire is which?
Dereck
06-29-2013 03:12 PM
Camper Bill
1999 to 2016 Super Duty
05-20-2013 06:00 PM
TNT in Round Rock
27
12-13-2012 09:32 AM
Truck Paradise
Ohio Chapter
02-13-2012 01:48 PM
