I just change oil, gas and air filters. Change sparks plugs, but i still got this little jump on the engine. this happen on 45 MPH and around 3000RPM. Can be COP? How can I check which one is the bad?
I got a 2000, SD, 5.4 with 215963 miles on this truck.
I am having the same problem i would say that the coil has not gone all the way out but is close so you could take it to a shop and spend about $250 or do it your self. If you do it your self you I would have someone stand by your exhaust and you pull the coil wires one at a time till it sounds better. When you drive it and it does not help you might have more than one out or did not get the right one. I would say if you have the money do all 8 because once on went out on mine they all started going out.
