Introduce yourself and your ride here!
#61
#62
Oh dang, I bet you are just getting ripped. I used to have a ranger that didn't have power steering. I cut out the fender wells and put 31" BF Goodrich all-terrains on it. Good way to keep your arms in shape.
I would say for starters to make sure that your tire pressure is all good. That wont fix the leak but it sure makes it easier to turn.
Then, check for any leaks in the lines. Jack up the front end......or drive onto some cardboard in a gravel area since you dont have a jack, and have a friend turn the wheel as you look for the leaks. Not sure if your truck runs off of the same pump for the brakes but mine does. If that is the case have your friend pump the brakes and turn the wheel.
#63
#64
#66
#72
Is it actually leaking PS fluid? Even leaking it should still work unless the gear inside is broken. Also it sounds like the brake differential valve is tripped and not making the back brakes work. There is a block on the frame rail that all the lines meet up and equalize, its got a safety so if the front or rear blow out it won't dump all the fluid.
#73
on
Greetings,,, My name is Liz,,, I don't live in Montana but have always wanted to visit!!! Does that count?? LoL!!
My ride is a Vestas V82 Wind Turbine,,, 76 of them actually!!! I love the way they rock around in high winds!!! Oh, wait,,, that's not exactly what you meant is it?? Ooops!! My bad!!
My other ride is in my Garage!! Just click on the linky and have a peek in ya really want to see!!
#74
Hi Liz!! You are more than welcome here anytime!! Great place to live and visit as well.
I don't think thats what they meant when the said "fringe benefits"
#75
