Intermittent wiper controls
Old Jun 24, 2009 | 10:30 PM
barbsbuddy's Avatar
barbsbuddy
I am parting out a '79 Bronco and would like to use the intermittent wiper feature in my '76 F-250. Do I need more than the wiper switch that is dash mounted? I am thinking there is probably a module on the firewall or where ever that is installed between the switch and the wiper motor.
Thanks for your help.
Old Jun 24, 2009 | 10:39 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You're right, there is a little control box on usually on the firewall.
Josh
Old Jun 26, 2009 | 11:21 AM
1977f250's Avatar
1977f250
Mine was mounted with two screws on the back side of the lower dash. Pull the switch and you cant miss it. It will be about 6" or so from the switch in the wiring loom.
