$400 + & still runs like crap
About 2 months ago I ran out of gas. My gas gage doesn't work. A day or two later my truck started running like crap. Missing 7 kind of chugging. So since I haven't tuned it up in a while I changed the fuel filter, plugs, wires, dist. cap ,& button. It ran good after that for a few days but I could tell it wasn't right. Then it started running like crap again. I took it to a mechanic & he replaced the ECM, TPS, & the idle air controle. It ran good for a day or so but I could tell it still wasn't right. Yesterday I was going down the interstate & it started running like crap again. I'm PISSED! Any ideas?
If you are going to the trouble of doing the in tank fuel pump make sure to spend the extra cash and get the new sending unit with it so your gas gage works again!
whyjay, you are getting some REALLY bad advice in this thread. 17fordguy, you must be an absolute genius if you can diagnose a bad fuel pump without knowing ANYTHING about the problem other than the truck doesn't run right.
Replacing the high pressure pump (you have one, it's external) is a waste of time and money unless you have tested the fuel pressure with a gauge and confirmed that the pump is failing. Running a tank low on fuel will not cause a fuel pump to fail.
First thing you should do is describe the problem. "runs like crap" doesn't tell us anything. Also remember to post as much information about your truck as possible. Year, engine, transmission, mileage, recent repairs, etc are all helpful information and you have given us none of that.
One of the first things you are going to have to do in any case is pull the codes from the computer. You can either do it the free but error-prone way using a paperclip (http://broncodata.com/tech/codes.htm) or you can buy a code reader for about $30. People misread codes all the time using the free method, but the code reader is pretty fool-proof. I bought an Innova 3145 a while ago and it's super handy.
BTW, you could have saved yourself a lot of money by replacing those three things yourself, they are very easy to get to and would have cost you about $120 total - but I doubt there was anything wrong with them to begin with. Mechanics love to throw parts at the problem without diagnosing it properly, this makes them money and keeps you coming back.
Never had to replace the pump, and it had the internal high pressure pumps.
It also makes NO sense why running a tank dry would damage an external pump. I can kinda see how it might shorten the life of an internal pump, because the fuel will help keep it cool.
Bottom line is that advising someone to spend a couple hundred bucks and a few hours of his time to replace a fuel pump without bothering to check the fuel pressure is bad, lazy, sloppy advice.
