Engine help please
Old Jun 24, 2009 | 06:23 PM
r-kid's Avatar
r-kid
Engine help please
I have a 2000 7.3 psd 126000 miles . 2 weeks ago I posted here about the engine running rough. It cleared up and then started acting up again. I took it to a diesel repair shop and they can`t figure it out. Here are the symptoms. Truck starts up rough with eratic idle for about 10 seconds then settles down. The next mile of driving is like a gas engine with a fouled plug, after a mile it runs normal untill it is shut down and then it starts all over again. The mechanic found fuel laying in the manifold between the heads, he wiped it up and said it was the o-ring on the fuel filter but that wasn`t it obviously. Any help would be greatly appreciated. Thanks Ron
Old Jun 24, 2009 | 07:03 PM
zx250's Avatar
zx250
Of the next Riffraff East
More likely, the fuel came from the fuel drain valve orings (replacement part available from Diesel 0 ring.com. Link in sig) It would have to be a bad leak to affect engine, unless bowl is draining while setting, then air gets in fuel rails and clears after a short drive. Hmm, could be. Check and see if you are still getting fuel in valley of engine.
Old Jun 24, 2009 | 07:37 PM
F350-6's Avatar
F350-6
The drain valve o-rings are the most common source of a fuel leak unless you just changed the fuel filter and the seal there didn't seat right.
When your truck acts up, does the check engine light come on? How old is your engine oil? Is it full? What type of oil are you using?
Old Jun 24, 2009 | 08:10 PM
r-kid's Avatar
r-kid
oil was changed 2000 miles ago. engine light does not come on. Not sure on the type of oil, I have had it serviced at the same place for 9 years.
Old Jun 24, 2009 | 08:18 PM
zx250's Avatar
zx250
Check for signs of more fuel on top of the engine, follow this link, http://www.guzzle7pt3.com/fdrain.php and fix that problem, then see what happens.
Old Jun 24, 2009 | 08:42 PM
r-kid's Avatar
r-kid
There is a very small ( maybe a teaspoon) amount present, but I do not know if the mechanic got 100% of it when he worked on it. Also it doesn`t do it all the time . It`s driving me nuts. Thanks
Old Jun 24, 2009 | 09:47 PM
nissandoc's Avatar
nissandoc
Have you checked the uvch? When mine acted up it would run rough, die then start right back up and be ok till the next time I started it.
Old Jun 25, 2009 | 01:11 AM
Visseroth's Avatar
Visseroth
Yea, sounds about right to be, either air in the fuel rails or loose UVCH. I pulled my valve covers off today just to do the quarter mod and torque things down so I don't end up in situations like this. No offense, just planning ahead and trying my darnedest to learn from these great group of peeps.
Old Jun 25, 2009 | 06:18 AM
r-kid's Avatar
r-kid
What is a UVCH, is it hard to fix? also I am not noticing fuel leaks. Thanks guys your a help. Ron
Old Jun 25, 2009 | 08:02 AM
nissandoc's Avatar
nissandoc
Under valve cover harness. They are known for coming disconnected. Its what connects your glow plugs and injectors.
check out this thread: https://www.ford-trucks.com/forums/8...ml#post7630914
Pay attention to the harness where it is coming disconnected.
Old Jun 25, 2009 | 08:09 PM
r-kid's Avatar
r-kid
The engine has been running fine today since I filled the tank. Everytime it ran rough the fuel level was slightly below an eighth of a tank. I don`t know if this is coincidence or not.
Old Jun 25, 2009 | 08:13 PM
zx250's Avatar
zx250
That's your problem, you're sucking air from the poorly designed fuel pickup. You can fix it with some in tank mods. or just keep your tank level above 1/4.
Old Jun 25, 2009 | 08:20 PM
danskool's Avatar
danskool
Go Bills !
Wondering if you screens are clogged in your tank. Below an 1/8 of a tank? If i hit a 1/4 i panic. The last 1/8 could be all diesel foam shake ..
Good write up on the tank mod. http://www.guzzle7pt3.com/hutch.php
Screens in tank
RDS0130
Apr 12, 2013 09:32 AM
Dieselexic
Feb 7, 2013 07:07 AM
bushman31
Aug 13, 2011 09:51 PM
bushman31
Dec 2, 2006 10:39 AM
fiyrman
1997 - 2003 F150
Oct 16, 2006 06:23 PM
