Thank you, I will give that a try. I have heard everything from you need to replace both airbags and the Sensors to just the clockspring. I hope to have an easy and not too expensive fix, as I just purchased the truck!!
Thank you so much for the pointers!! I replaced the clock spring this morning and when we took it out, it basically fell apart. That was the problem and the light is off...YEAH...not a more expensive fix!!
PwrstrkAndie
2000 F250 7.3L
It's a pretty common issue. If anyone else needs to replace one we carry new clock springs that are alot less money than the dealer.
