Best tire pressure for long trip
got the same truck...
You can bump the presure up to the max on the sidewall without issue except for the harshness of the ride you may get on secondary roads...
typically the interstate ride will be fine....
It saves a tiny bit on the mpg, but I think the best benefit I found was that I got 83k miles out of the original bfg rugged trails !!!
For long trips I like to use the maximum rating on the side walls.
I just did a 2700 mile trip from South Florida to Los Angeles and had my tires at 80psi and my air bags at 30psi. I had 5 people in the Ex and was towing my wifes Dodge Charger. The Ex did better than I could have imagined.
Here's what a Cooper rep told me(after them giving me 2 sets of tires on wifes car)
1) Go with what door sticker say
2) If you load heavy(in truck), then can add 10% of (1)
3) Can go to Tire Max Pres if you load heavy and pull trailer, But not over Max Tire pres.
4) ** Take pres down back to Door sticker pres after heavy trip**
*** Just never below door sticker ***
should be said, all psi should be cold psi....
we all know there can be a lot of difference between cold and hot air pressure, right ?
Heck, I've even measured a big diff from the sunny side of the truck to the shaded side.... so take it all into account
I found the door rated 50/55 PSI caused more wear on the inside/outside of the tires then in the middle. Have been running 70 PSI since 55,000 tire miles and inside/outside wear has stopped. Now have 63,000 tire miles on the X and will probably get another 15,000 to 20,000 miles out of the tires. Best truck tires I have ever had. Michelins installed at 15,000 truck miles.
DSMMH
I have heard of the chalk test - it's a good way to get the best contact patch down on the ground. Here's a slightly different way:
Weight of truck x Max tire PSI as indicated on sidewall
Tire max load rating (lbs) multiplied by 4
or:
7100lbs x 80psi
3415*4 = 13660
568000
------- = 41.6psi
13660
This supposedly gives you the best tread contact - but I certainly wouldn't run less than the door/gas label says. For best mileage and towing it seems like the max pressure is the best way - although with a firmer ride. The max load of the tire is calculated with the max pressure (cold) so keep that in mind for what ever you are towing/hauling.
or:
7100lbs x 80psi
3415*4 = 13660
568000
------- = 41.6psi
13660
socalsailing
09-26-2007 07:11 PM
state
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-27-2003 10:57 AM
