Sponsored by: Real Truck
limited slip not working
Old Jun 18, 2009 | 04:29 PM
maddogken's Avatar
maddogken
i have a 2002 CC f-250 5.4 4x4 and the other night i got over a bank and started spinning, i noticed only 1 tire turning over. could my LS rearend need friction modifier added?
Old Jun 18, 2009 | 04:35 PM
dkf's Avatar
dkf
Sounds to me its "Working as Designed". The stock "Limited Slip" is just that, limited. Adding friction modifier will only make it perform worse, if thats possible.
Robs06SuperDuty's Avatar
Robs06SuperDuty
how many miles are on your truck? if its got a lot of miles on it it may need rebuilt.
Old Jun 18, 2009 | 05:14 PM
EXv10's Avatar
EXv10
Modifier won't help.
Old Jun 18, 2009 | 05:24 PM
maddogken's Avatar
maddogken
ok, thanks
Old Jun 18, 2009 | 06:16 PM
RagingBull2k2's Avatar
RagingBull2k2
if you don't put any modifier in a rear end that needs its, you will blow the thing to hell (don't ask me how I know, lol)...
Joey
Old Jun 18, 2009 | 06:22 PM
EXv10's Avatar
EXv10
You only need modifier if the clutches are chattering. Do some more testing, the rear end needs some wheel contact/friction for it to work. It won't work if there is almost zero friction on one wheel.
Old Jun 19, 2009 | 01:48 AM
seminaryranger's Avatar
seminaryranger
As the others have said, it's working normally. Unfortunately. The limited slip differential is very mild.
It'll probably spin both tires at the boat ramp or on a snowy road or in light mud, but even then you just never know. The minute you start talking about driving across banks, ravines, wash-outs, ditches, or any other surface that articulates the suspension, be prepared for a one-wheel-peel.
There are several figures floating around regarding the break-away torque designed into the clutch plates of the OEM limited slip carrier... they've all been under 75 lb./ft. when new! That aint much. That's low enough to spin one tire even if both wheels were level on the ground. Put one tire in clover and the other on grass- there's a good chance the tire on clover will spin.
Old Jun 19, 2009 | 10:29 AM
EXv10's Avatar
EXv10
Right, like the positraction they need some resistance to work. With a stick shift and plenty of HP you could smoke both tires and then go to a slippery mud puddle and just spin one. The initial preload is just to keep it snug so they are quiet. If you had one side on rollers it would just sit there and spin that wheel.
Old Jun 19, 2009 | 10:37 AM
dkf's Avatar
dkf
I've got amosil 75-140 Severe Gear full synthetic in 10.5 with NO modifier and get zero chatter. If you do have excessive chatter only add small amounts of friction modifer until the chatter goes away. But anyway friction modifier won't help the OP.
Exactly. I can leave "Posi" marks on a dry road only when going stright but if theres a slick spot in the road the wheel with the least traction will unload.
