4x4 Auto (shift on fly) not engaging?
#46
MacGyver76,
Here's a couple of photos of one of my old EFOS hubs. Maybe the grip and basic shape can help you determine if you have the auto hubs or not.
Rick...
Rick...
Thanks for clearifling that for me.. but that is the only hose other than the brake line.. so either they took off auto with a hub swap or lines were damaged so they took off.. How can I find out if the hubs are auto/lock or freespin/lock hubs? too warn around the edge to read anything..
Thanks again..
Thanks again..
#48
Correction from previous post:
ESOF not EFOS. argh,,, The edit botton disappears too fast for my bad speeling needs.
MacGyver76,
Do you have the shift on the fly switch on your dash? or a manual floor shift?
- Switch On Dash = YES you should be able to get auto lock working (with correct hubs, vacuum solenoid, vacuum lines and working dash switch)
- Shift On Floor = NO auto lock,,, unless you invest pretty big money into transfer case and other parts needed.
Rick...
MacGyver76,
Rick...
Ok now im really . According to this thread. This is what they said below:
So is this why mine won't auto engage?
My hubs look simular to _Rick_ minus the hoses. It has a rubber stop cap on it. So could I add for it to be auto locking on the fly?
Thanks
Thanks
#49
ESOF not EFOS. argh,,, The edit botton disappears too fast for my bad speeling neads.
MacGyver76,
Rick...
MacGyver76,
Rick...
Yes mine is the floor shift.. Of all the post that I read about people having issues with the front diff non said anything about the dash or floor shifter till that one post. Wasted so much hard drive space asking and try to figure this out.. .
Truthfully, I didn't think they made manual only hubs anymore since the 80's etc.. DOH!!!
Thanks for all your help though.. Sorry for wasting everyones time..
#50
Ah, I guess this worked out in the end
Some of the confusion comes from certain trucks having the shifter on the floor, but "auto locking hubs". Not sure if it's other brands, or other years of Ford trucks, or both, but there exist some trucks that you can shift into 4x4 with the lever on the floor, and they have a vacuum system that will lock the front hubs.
As in, the Ford F150. It has no manual hubs. It does, however, have a vacuum system that locks the axles at the front differential (independent front suspension) and doesn't have "locking hubs".
#51
MacGyver76,
No problem with the time. At least you got to the bottom of your investigation.
Don't be disappointed with the fact you have a manual system. Odds are it will end up saving you or the next owner of your Truck some money because the ESOF system is known to fail causing headaches. I will fight to the death to keep mine running smooth simply because I like it (when it's working properly).
I found out only a few days ago after testing my system with a vacuum gauge I need to replace my hub assembly yellow o-ring (drivers side). I will end up doing both sides for piece of mind, but for me it's worth the effort.
Rick...
Rick...
Sorry, could of swarn I put that in there.. Just got off a 1600 mile trip. Now getting up and around to go to Wisconsin and Chicago. So was little tired last night..
#53
#55
Originally Posted by _Rick_
MacGyver76,
Rick...
Rick...
Guess I was getting confused cause my wife's Dodge has the shifter for 4x4 on the floor and has no locking hubs. but shifts on-the-fly... So just didn't know how fords were as this is my first ford.
Thanks
#56
#57
Hi 2003RedSuperDuty,
First,,, welcome to the FTE forum.
At a glance I would guess the switch is faulty.
Rick...
Rick...
#58
I had a new tranny put in today (Christmas Eve). I got into some of the Texas/Oklahoma blizzard and turn on the ESOF and it didn't work. I stopped and manually locked the hubs and still nothing. Apparently the transfer case is not engaging. Any suggestions where to start looking? I'm stuck in Amarillo until I get it fixed or the roads clear.
#60
My apologies for the bad info!
