1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Low range 2wd switch
Old 07-13-2009, 05:42 PM
hammer65's Avatar
hammer65
hammer65 is offline
Got to test my Low range 2WD switch out this weekend. Works just fine, I cut the red wire to the vacuum switch, and ran it through the rocker switch. I also have a reminder that it is on. The A/C goes to defrost.
Old 07-13-2009, 08:20 PM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
Good deal! Glad to hear it worked out for ya. This is a low priority task on my to-do list because it could occasionally be useful for me and I'm a sucker for another switch on the dash
Old 07-14-2009, 05:07 AM
hammer65's Avatar
hammer65
hammer65 is offline
I just wanted it for backing my 5vr up the hill at home. Jim
Old 07-14-2009, 10:04 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
That's weird. If you disabled the vacuum solenoid totally, you wouldn't have a vacuum leak. ?
Old 07-14-2009, 10:34 AM
12ozd's Avatar
12ozd
12ozd is offline
I agree, gotta think about this one.
Old 07-14-2009, 11:00 AM
brian42's Avatar
brian42
brian42 is online now
I agree. Sounds like you have a vacuum leak and your hubs aren't locking anyway, so be default you already have 2lo.
Have you tried using your ESOF to lock the hubs recently?
Old 07-14-2009, 11:09 AM
GregsSD's Avatar
GregsSD
GregsSD is offline
I think you cut the wire to the vacuum pump instead of the hub solenoid if the A/C switches to defrost.
Old 07-14-2009, 11:36 AM
brian42's Avatar
brian42
Sounds more like you cut the vacuum line to the solenoid instead of the wire....
Old 07-14-2009, 01:04 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
It is becoming clearer ....
Old 07-14-2009, 01:55 PM
12ozd's Avatar
12ozd
12ozd is offline
He said he cut a red wire,there is no red wire on the vacuum pump.
There is one to the solenoid.
Maybe broke or knocked loose a vacuum line?
Blew a fuse ?
Old 07-14-2009, 01:58 PM
12ozd's Avatar
12ozd
12ozd is offline
Works just fine, . The A/C goes to defrost
If you're happy,we're happy,
but that's not the way it should work.
