Transmission out?
Old Jun 10, 2009 | 04:36 PM
Chevy 6.2D's Avatar
Chevy 6.2D
Cool Transmission out?
My '91 F150 has a problem. It won't move. If I let the clutch out in 1, 2, 3, or 4 it just kills the engine. (it also won't roll unless the clutch is pushed in) If I put in neutral, 5th or reverse it backs up. I'm thinking a broken fork but what should I do? Pull the tranny?
Old Jun 10, 2009 | 07:15 PM
nnewman's Avatar
nnewman
You should be able to access shift forks from the top. Pull back the carpet & there is a plate bolted to the transmission tunnel. Once that's off you can unbolt the top plate from the transmission & see the shift forks.
