Doe?s my F350 qualify for Truck plates - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Virginia Chapter
Reload this Page >
Virginia Chapter Join Chapter, Leader:
Old 06-08-2009, 08:12 PM
svector51
svector51 is offline
svector51 is starting off with a positive reputation.
I own a 2004 F350 Superduty, extended cab, long bed, V10. It is stock. I called DMV and asked about replacing my passenger tags with "Truck" plates and their answer was not clear.
They told me the truck has to have a GVW of >7500 lbs and mine lists as 7500. I told them I had a tool box installed and asked if that would put it over the 7500 lb limit. They weren't sure and suggested I go to a branch. I might rather have a root canal.
Anyone have exerience with this in Virginia.
It is of some personal benefit to me if I can display the Truck tags, as my HOA will allow me to bring the truck into my townhouse community to work on my OWN house but without then I can't.
Old 06-08-2009, 09:00 PM
MissIndependent's Avatar
MissIndependent
MissIndependent is offline
MissIndependent is gaining momentum as a positive member of FTE.MissIndependent is gaining momentum as a positive member of FTE.
i'm sure your truck would qualify, but i'm not sure i'd go through the hassle...i wanted to have private truck tags just because when i first got mine. however, i found out you'll be taxed at a much higher rate on the vehicle plus the bother of finding the form to change your gvw and then having a dmv employee come look at your vin sticker to verify...blah blah blah...
besides all of that, the man i dealt with was one of those [email protected]#$ sexist jerks who automatically assumed that i didn't know the first thing about my truck
Old 06-08-2009, 10:08 PM
SSG VA BEACH's Avatar
SSG VA BEACH
SSG VA BEACH is offline
SSG VA BEACH is starting off with a positive reputation.
Man wtf is up when you can't have your private truck parked at your house. I would try and get a waiver or something from the HOA. I do work on houses and am always encountering arbitrary enforcement from HOA's that don't make sense. I could understand a motorhome or boat or semi-trailor. Sorry for your trouble and glad I am in an area that so far is HOA free.
Old 08-31-2009, 01:32 AM
tbear853's Avatar
tbear853
tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
You simply misunderstood.
If you register it for a GVW (gross vehicle weight) of 7501 pounds or more, you will get truck tags. GVW is not GVWR which is the manufacturer's gross vehicle weight rating that DMV is interested in.
A F-350 probably should have truck tags if it's ever used to haul what it was built for. They weigh 6,000 or more empty.
Link
"Pickup or panel truck" means every motor vehicle designed for the transportation of property and having a registered gross weight of 7,500 pounds or less.
"Truck" means every motor vehicle designed to transport property on its own structure independent of any other vehicle and having a registered gross weight in excess of 7,500 pounds.
Old 09-01-2009, 05:31 PM
Franken-Truck's Avatar
Franken-Truck
Franken-Truck is offline
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
can you just tell the HOA to go F-off?
DDDDDMorgan
Fifth Wheel & Gooseneck RV Towing
09-06-2016 11:15 AM
texastech_diesel
1999 to 2016 Super Duty
31
08-15-2016 10:26 PM
Oz Econoline
33
06-25-2016 12:36 PM
Cody_1948
42
03-25-2016 09:05 AM
katster
06-13-2011 11:51 PM
Quick Reply: Doe?s my F350 qualify for Truck plates
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
