[updated:LAST EDITED ON 24-Mar-02 AT 10:41 AM (EST)]Depends on which side of the fork. If it's on the engaging side, I would say that is a possibility. In that case, the slider may not completely engage the clutching teeth on the 3rd gear, allowing the trans to "jump out."
Does the slider have a definate "click" from the synchronizer when you engage it with a big screwdriver? If not, you may have synchro problems.
Art
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3068&.jpg
The engaging side is the one that pushes the slider into the 3rd gear's clutching teeth. Watching the shifter as you put it into 3rd may help.
Art
