93 f250 4x4 unicorn???? (front axel question)
So im very confused of what to make of my truck. its a 1993 f250 4x4 7.5L.
i went to put some blocks on my front end to level it out today. and i came the a shocking realization that my solid front axle of leaf springs is not solid. it looks like a solid front axle but it bends in the middle.
When i lifted it the bottem of the wheel was to far in, and the top of the wheel was to far out.
my grampa called it a twin i bean axle.... iv never seen this befor, nor has any of my friends(they are all about longtravel 2wheel drives :-( )
so my question is.
what is it that i have. good bad or ugly?
How do i lift it?
And how do i keep the front end aligned?
im so confused. kinda sad its not solid. and i dong know what to do. how much will it cost..... Blahhhhhhh... heart broken
so my question is.
How do i lift it?
You have a TTB front axle, The only axle avaliable in a 4x4 F250 from 80-97. And you can NOT use blocks in any front suspension ( EVER ). Just look up ford f250 and you will find about 10 different companys making leveling kits.
A D60 (solid axle) swap is a commom swap fro these trucks. The TTB is prone to ball joint failure, and premature tire wear. They are far from an ideal front axle
how complicated is the swap. how much fab. and how much does the axel usual run for.
Just a note, for these years of trucks:
F-150 -> Dana 44
F-250 -> Dana 44 or Dana 50 (check casting number on differential)
F-350 -> Dana 60
so my question is.
How do i lift it?
so my question is.
How do i lift it?
2. You probably have a D50 (just speculating, could be a 44, but unlikely due to the 7.5L) which a lot of people don't like. Granted it isn't as tough as a Dana 60, but it will stand up to plenty of abuse. I've run mine into plenty of things and an waiting for it to fail to replace it with a D60, but that hasn't happened yet.
3. Lifting the TTB is more expensive than a solid axle. What I would recommend if you want the solid axle and a lift is to swap in the solid axle, an extended pit man arm, front and rear lift springs, and possibly longer drive shafts if necessary. And of course deal with any brake line issues or whatever as they come up.
4. You don't really keep it aligned... I can honestly say that last time I got an alignment, it was gone before I got home.
Hope this helps a bit.
Came across this article, might be relevant?
1989 Ford Bronco Suspension - 4-Wheel and Off-Road Magazine
on
all front ends are posi correct?
if not,are these? do they come both ways?
how could i tell?
thanks.
one other newbie question.TTB stands for?
Posi is the chevy term for a limited slip differential, ford calls it Trac-Lok. It is possible that your truck could have one, but its super rare in the F150s, on clue on a 250. TTB stands for twin traction beam, its the 4x4 version of Fords twin I beam that they have been using for a good 40+ years now. To tell if you have a limited slip diff in the front, jack up both front tires off the ground, lock in the hubs and spin a tire. If the other tire spins the same way its a posi/limited slip/trac lock, if it spins the other way its an open diff.
on
