93 f250 4x4 unicorn???? (front axel question)
Old 10-15-2009, 05:55 AM
DarrinGT's Avatar
DarrinGT
DarrinGT is offline
DarrinGT has a good reputation on FTE.DarrinGT has a good reputation on FTE.
The easiest and safest way to level out the truck is a an add a leaf leveling kit form Rough Country. JC WHitney sells them for about $100.00 I have used them on 4 trucks.
You may have to adjust your camber once it is completed.
Old 10-15-2009, 07:12 PM
fordman1090
fordman1090 is offline
fordman1090 is starting off with a positive reputation.
the ttb front is perfectly fine for casual off roading. They are actually pretty good for sand, and going fast on rough roads and jumping. But they often fail when they have lockers and big tires and get into a bind.
And keeping them in alignment is another common problem. But i think that has more to do with the shop not doing a full alignment, including the camber adjustment.
Old 10-15-2009, 07:30 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
Originally Posted by ford96f150 View Post
awwwwwwwww man!
all front ends are posi correct?
if not,are these? do they come both ways?
how could i tell?
thanks.
one other newbie question.TTB stands for?
NO. Not posi.Ford calls it limited slip. I do not believe ford offered a front axle w limited slip since the 70's
The tag on the axle w say if it is limited slip or not. On the tag right at the bolt it will say
3.54(open diff)
3L54(limited slip
3.72(open diff)
3L72 (LS)
4.09(open diff)
4L09(LS)
Usually the first number is covered w the head of the bolt
Old 10-17-2009, 08:11 PM
capn kirk
capn kirk is offline
capn kirk is gaining momentum as a positive member of FTE.
pretty sure my gears are factory and im 99% sure the front is ls
Old 10-17-2009, 11:35 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
FORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputation
i was really hoping the front would be LS.bummer.
confirmed by jacking it up/locking in both hubs like suggested and saw the wheels spun in opposite directions while spinning one wheel.
Old 10-17-2009, 11:46 PM
joe f350
joe f350 is offline
joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.
i have a d44 in my f350 pervise owener did it been a good axle so far and i run 37s
SVTDriver97
WTB - Parts & other
02-20-2017 12:14 PM
RedDevil460
38
02-24-2013 09:32 PM
taylorjs
1999 to 2016 Super Duty
03-26-2010 05:58 AM
gman30
07-28-2009 10:27 PM
az4x4bronc
1978 - 1996 Big Bronco
43
01-14-2005 08:07 AM
Quick Reply: 93 f250 4x4 unicorn???? (front axel question)
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
