AOD Transmission Recommendations for a 408W
on
Yikes!! You probably want to have a look here... Ford-AOD.com the ultimate AOD Transmission Perfromance Website
When I had the 5.0 in my `90 F-150 I rebuilt the trans w/ TCI Pro-Super rebuild kit and it worked like a champ. Then I swapped in a HP 351 and I broke the input shaft on the trans,so I ordered a TCI Super Streetfighter trans from Summit. It`s non lock-up (supposed to be stronger),has the hardened input shaft and 3500 stall,B+M truck floor shifter,deep pan and cooler w/fan,and I`m using TCI synthetic fluid that cost $100+ a case.When I had the tranny out I stroked the motor to 393.It runs mid 13`s w/stock 3.55`s and no posi and no traction.You `ll need hardened shafts and a good cooler for sure.
crashmaster79
05-10-2015 10:20 AM
Blue80
06-01-2009 04:37 PM
alk3myst
1978 - 1996 Big Bronco
07-28-2003 09:21 AM
