The Beast, my F250 prerunner
I built this truck to have fun with my friends in the desert because I gave up riding dirt bikes, here's a little info on "The Beast" my Ford Prerunner, It has rearches I-beams that were bent on a 10 ton press at Autofab and they have been totaly rebuilt using brass sleeve's with new king pins. This truck has a Full Roll Cage inside and out. It has Bilstein Shocks with four 7100s series in the front and two 9100s series in the back. It has a 390 Engine with 72,000 original miles on it, 4 Core Radiator, Milodon oil pan, Headman Headers, Edlebrock Intake, Demon 650 Carb, Mallory Pointless Distributor, MSD Plug Wires, K&N 5" Air Cleaner, Flowmaster Exhaust and Optima Battery. It also has 5-Point Corbeau Racing Seats with 4-Point PyroTech Harnesses. Suspension has been fully updated with new National Springs in the rear and Fabtech Springs in the front. The suspension has 16" travel up front and 18" travel in rear. The suspension has been fully cycled by Off Road Unlimited and has Pyrotech limiting Straps already installed. It has a Dana 60 Diff and the brakes have be totally rebuilt with new calipers and Stainless Steel Brake Lines. Truck has Fiberglass Bedsides make by "Autofab" from the trucks old bed. They have Re-Arched Wheel Well Openings and an added Flare. It has a 32 gallon Fuelsafe racing fuel cell hooked up to stock gas gauge.
This truck has been designed to be able to drive from your house to the desert and also has a Receiver Hitch welded into the frame. Its a 3/4 ton so you can pull just about anything with it, Toyhauler/Dirtbikes/boat/what have you. Also this truck is Fully Street Legal and Smog Exempt.
HEAVY100
80
11-17-2019 01:07 AM
Fordester
49
06-16-2013 01:28 AM
black58
17
06-04-2012 04:00 AM
