1955 F250 Rear Suspension Restoration Questions?
I finished the restoration of my rear end this past weekend. Now I want to concentrate on the leaf springs, shackles, pins, zerks, bushings, u-bolts etc. So what is the safest way to disassemble the leafs from each other without them cutting my head off once they release? Any other tips are appreciated.
I sandblasted the steel pins/dowels that slide through the frame and into the leaf spring bushings. I have a feeling this was a mistake on my part b/c they are now slightly rough as opposed to that polished smooth look. Do I need to buy new pins now since I sandblasted them to a slight rough texture? I hope I didn't ruin these.
For parts like these, does it just make more sense to get all new parts (bushings, pins, set bolts, zerks, etc) from Mid-Fifty minus the leafs?
the use of a police bomb disposal robot and a a hot wrench ?????????????? mine didna come flying apart on the 1 ton or any of the 1/2 tons i've dissassembled to this point . wrap a piece of chain round 'em if your concerned with a bolt to hold it in place / together . now if it was a coil spring , welp yeah they can do some unexpected things when your trying to work with 'em and you aren't thinking ...............
Thanks guys for the C-clamp idea. I think the leaf springs are under about 1/8 - 1/4 of tension per leaf, and once you release the center bolt and start loosening the C-Clamp then it starts to separate, nothing violent though.
I was able to push out the bearing off of the non-pin shackle side, but the bushing on the other end where the pin shackle is mounted was an absolute beeoch. I used my 12 ton press and it didn't come out. So I took a 3/4" socket and a BFH and knocked the snot out of the bushing until it came out. Unfortunately my 3/4" socket was stuck then, but the 12 ton press was able to push that out.
Anyway, its time to complete a list of new bolts, pins, set pins, bushings, zerks, etc for the suspension and place an order at Mid-Fifty this week. Sanding, primer, and paint should be completed this weekend if all goes well.
