Leaking rear seal---How do tell rear axle type
Old 05-27-2009, 04:56 PM
Jeeper1911
Jeeper1911 is offline
Jeeper1911 is starting off with a positive reputation.
Door code is 35 and that tells me gear ratio but not maker or size. Tag on rear end "V129C 10 10 2 9C28". need to know for seals and bearings. How hard to change? 1989 F250 7.5 4 speed w/od ext cab long bed.
Old 05-27-2009, 05:30 PM
jr32560's Avatar
jr32560
jr32560 is offline
jr32560 has much to be proud ofjr32560 has much to be proud ofjr32560 has much to be proud ofjr32560 has much to be proud ofjr32560 has much to be proud ofjr32560 has much to be proud ofjr32560 has much to be proud ofjr32560 has much to be proud of
just go to the parts store and tell them all the info on your truck-that's what i did-but mine was a major pain in the butt!
Old 05-27-2009, 06:42 PM
fordpower46
fordpower46 is offline
fordpower46 is starting off with a positive reputation.
its a ford rear, probably a 10.25 but the best thing to do is to count the number of bolts on the cover. what seal is leaking?
Old 05-27-2009, 06:48 PM
F150xlt
F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
Door tag 35 = Rear Axle capacity 6250 lbs. 4.10 Ratio
V129C = Manufacturing Plant Van Dyke Plant I believe it's in Warren, MI
Conventional Diff. Single Rear Wheel.
I believe the 10 is for 4.10
The other 10 2 is for 10.25 Ring Gear Diameter
9C28 is the Build date Year-Month-Date
Old 05-27-2009, 07:05 PM
subford's Avatar
subford
subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
March 28, 1989
Old 05-27-2009, 09:29 PM
Jeeper1911
I have gear oil coming out of brake adjusting slot on back of brake. Number of bolts are 12. How hard a fix is this.
Old 05-28-2009, 01:32 AM
LCAM-01XA
LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
You have a Sterling axle, the full-floating version of it. It's a very good axle, but there are three known issue with it:
1) wheel hub seals wear prematurely and develop leaks.
2) if lots of engine braking is done while hauling heavy, the crush collar on the pinion gives a bit, thus causing slop in the pinion and premature wear of both that and the ring gear.
3) the bolts that hold the ring gear to the diff case can back out, results are fairly disastrous - if a gear swap is ever done to one of those axles, high-strength thread locker must be used on the ring gear bolts to prevent that from happening.
Seems to me you have #1 going on for ya. To get those seals you will have to take the wheels off, then pull the axle shafts (that's what those smaller 8 bolts are for), and finally pull the entire wheel hubs (that requires a special tool for the big hub nuts). Additionally Ford attempted at some point to come up with a better design of seals, and failed again, there is however a company that makes very good double-lip seals that keep both oil in the axle, and water out of it. Unfortunately, I do not remember the name of the company or the part number for the seals, but IIRC these seals can be bought through NAPA. Someone else will chime in with more info, I'm sure.
Old 05-28-2009, 06:27 PM
F150xlt
F150xlt is offline
Click on the link below and print out the procedure to replace the axle seal.
https://www.ford-trucks.com/forums/8...fo-please.html
Old 06-11-2009, 06:42 PM
Jeeper1911
Need help with seal. I picked up one from Auto Zone, but it did not look like the same thing that was in there. Took it back thinking they gave me wrong part, again. Got another one from another place, they said one from auto zone was for a semi floater and mine was a full floating, ok. got mine tore apart and was same as the one from auto zone. NOW WHAT !
Old 06-11-2009, 07:15 PM
F150xlt
F150xlt is offline
If you pulled your axle like in this picture you have a full floating axle.
If you had to remove he rear differential cover and pull out a C clip you have a semi float rear axle.
Old 06-11-2009, 07:27 PM
subford's Avatar
subford
subford is offline
To start with a V129C is a 4.10:1 10.25 Non-Locking rear end.
The V129C was used in the 1987-1991 F250 HD & 1987-1991 F350.
Do you have to pull the axle out before you take the hub off?
If so it is full floating axle.
The part store should have been able to get you the right part from the V129C number.
As it was used in the F350 It would be a full floater.
Old 06-11-2009, 07:30 PM
andym's Avatar
andym
andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
It's a full floating sterling 10.25" axle. I promise.
Without looking at it, I couldn't tell you how to replace it, but a haynes or chiltons manual will have the procedure in it.
Getting the correct part is of course important.
Are you sure you're comparing the right seals?
Old 06-11-2009, 07:55 PM
Jeeper1911
Ok, so it's a full floating, I had to just take out bolts on hub and axle came right out. My problem is both seals were suppose to be for full floating, but they were very different. Auto Zone one had what looked to be rubber teeth at the back. The other had flat steel back that i just tapped around to seat. When I tried to put hub on it would not go all the way on. There was a steel piece on spindle that I thought was suppose to stay on. I tried pulling it off and it looks like seal had separated leaving this piece on. It has the rubber teeth around it! Now what? Can either seal be used????
Old 06-11-2009, 10:13 PM
subford's Avatar
subford
subford is offline
Here is the only image I have of the seal:
Old 06-11-2009, 11:17 PM
F150xlt
F150xlt is offline
Here's a picture of the rear hub inner seal.
Picture of inner axle seal.
Quick Reply: Leaking rear seal---How do tell rear axle type
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
