Code Help
Old May 27, 2009 | 02:40 PM
95 F150 Dude's Avatar
95 F150 Dude
Code Help
Guys,
I read the page on obtaining codes on my 95 4.9 but I can't seem to figure it all out. Here is the sequesnce:
1 1 1 1 1 1 1 7 2 and then another 1 7 2
This is with KOEO. I tried the parts stores but all they have is an OBDII scanner. Any help would be appreciated.
Scott
Old May 27, 2009 | 05:05 PM
EPNCSU2006's Avatar
EPNCSU2006
See if this diagram helps sort out the blinks:
http://www.thorssell.net/hbook/images/codes2.gif
The diagram shows 2 digit codes, but just add a digit before the between-codes pause.
Old May 27, 2009 | 05:48 PM
etldak's Avatar
etldak
code
172 is a 02 senser code
Old May 27, 2009 | 06:26 PM
95 F150 Dude
ETLDAK,
So you interpreted the sequence as a 172? I could not find a code 172 on the KOEO chart. There is a code 172 but it was on the KOER side and it said a "HEGO sensor on the right side". Thanks for your help.
Scott
Old May 27, 2009 | 07:17 PM
subford's Avatar
subford
The 172 you saw was a CM code and not a KOEO or KOER code.
It means that the engine was running lean during engine operation at sometime in the last 80 start ups.
Old May 27, 2009 | 07:44 PM
95 F150 Dude
Thanks guys! I will get started on that as soon as I get finished with the steering column swap.
Scott
