Working on a 1993 F150 XLT extended cab 5.0 that has wet carpet along the left side of the tunnel. Also found he coolant overflow bottle empty and radiator down 1 - 2 inches. Radiator and hoses are new within the last six months. Have also noticed at times a very small spot of coolant on the ground. All that to ask this question. Could a leaking heater core cause the left side front carpet to be wet?.
Its possible. IF parked at a angle it could run through the duckwork and come out the floor vent. Take a white paper towel and blot the wet area. See if the towel turns green from antifreeze or not.
