I need a Cam for a 7.3L
Old 05-20-2009, 11:57 PM
cappyd892's Avatar
cappyd892
cappyd892 is offline
cappyd892 is starting off with a positive reputation.
Hello, I have just pulled my motor due to low oil pressure and I have come to find that the motor has spun 2 cam shaft bearings and my cam shaft has some rough spots in it. I am pretty sure that I need a new one now. Im not sure about the block it is getting measured to see if it was messed up. But anyways my question is does anybody know where I can get a cam for a 7.3? Thanks
Old 05-20-2009, 11:59 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
Who is measuring the cam wear? If they don't know where to get one, go elsewhere.
Old 05-21-2009, 01:09 PM
Maintain's Avatar
Maintain
Maintain is offline
Maintain is starting off with a positive reputation.
Stock or modded?
DI and Carson both have cams that are getting it done. Maximum lift, no overlap.
Old 05-21-2009, 01:17 PM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
I know of a guy in the Seattle area that sells a custom ground cam (his own specs) that guys have been happy with as well.
Old 05-21-2009, 03:51 PM
cappyd892's Avatar
cappyd892
I took it to a local shop that works on diesel motors. I was just wanting to get some responses from people to see what some options are for one.
Old 05-21-2009, 03:54 PM
SuperDoodie's Avatar
SuperDoodie
SuperDoodie is offline
SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.
You can get your cam re-ground and brought back within spec.
Old 05-23-2009, 11:17 AM
mrwrench
mrwrench is offline
mrwrench is starting off with a positive reputation.
I have one
[email protected]
Old 05-23-2009, 11:27 PM
cappyd892's Avatar
cappyd892
Well it turns out that i need a whole new block. Mine is cracked where those 2 bearings were at.
Pincheweddo
03-10-2014 09:08 PM
traxx808
08-01-2010 12:54 PM
Kylet8020
02-10-2009 01:36 AM
98powerstang
51
01-07-2007 02:18 PM
T BLAUVELT
06-17-2003 03:33 PM
Quick Reply: I need a Cam for a 7.3L
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
