opinions on front axle right seal leaking
I was under the truck looking for the fuel filter number and noticed the right lower ball joint was damp. Had a drop of oil hanging from it but nothing on the ground where it is always parked. So, I did the google search for this site and read for about an hour on replacing the inner seal. Question that I have is can I put this off until after Memorial weekend if I don't use 4 wheel drive and top off the gear lube? I am driving 300 miles round trip for a camping weekend.
should be okay i just replaced my ball joints and have that same axle seal leaking ill post ford part # for you in about an hour, the seal is in the truck and getting ready for work...
to answer your question it should be okay to drive when the 4wheel drive isnt engaged the ring and pinion are not spinning so it should be okay.
Under the truck looking for the fuel filter number???
You will be fine for the weekend. FWIW FTEPARTSGUY (Ed) now has a kit with everything you need- ball joints, seals, everything needed to replace both sides. Very nice kit and well worth the $, I think I spent almost $200 on one side about a year ago!
I added the baldwin fuel filter when I did the hutch/harpoon kit. I was running a carquest filter because it's local and I can get it when I decide to change it.
Thanks for all the replies. I will plan to do this soon but glad to know I can get through the weekend as is.
click on the picture of the F650 to enter specials section.
and look on right side of page see 4x4 ball joint kit or 4x4 ESOF RESEAL KIT
thats them.
link
Th!nkPartsGuy/FTEPartsGuy
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
12-26-2023 11:24 PM
