External Transmission Filter
Old May 18, 2009 | 03:50 PM
figurhead's Avatar
figurhead
I couldn't find any thread containing info about the www.dieselsite.com 's external transmission filter setup. I am gonna order the coolant filter setup for my 03 f350 6.0l, but I wondered if anyone had any experience with their transmission filter? Sound like a good idea, but isn't there already an internal xnny filter?
Old May 18, 2009 | 05:33 PM
ljutic ss's Avatar
ljutic ss
Look up under the passenger side where the bumper meets the frame, you will see a canister with a hex on the bottom.
Old May 18, 2009 | 06:00 PM
figurhead's Avatar
figurhead
Sorry I can't check it out right now, since I am still on vacation in Kauai, HA. So your saying there is an OEM tranny filter, (front bumper/pasgr side). Where do you get the OEM filters and how often are they changed? I'll check it out in 2 days. Thanks.
Old May 18, 2009 | 06:24 PM
cartmanea's Avatar
cartmanea
You can upgrade to the '08 pan and filter. The new filter is a full flow small micron filter instead of just a screen in the pickup. I plan to do this next time I change fluid.
Old May 18, 2009 | 07:18 PM
figurhead's Avatar
figurhead
'08 pan/filter from the dealer, or aftermarket? And do the both come together (pan/filter combo) or are they sold separately? and where do you get the replacement tranny filter (passgr side/front bumper one)?
Old May 18, 2009 | 07:19 PM
liv's Avatar
liv
Check out fordparts guy he's a sponsor. He will get you a good deal on them. You will most likely have to order them seperate.
Old May 18, 2009 | 07:43 PM
figurhead's Avatar
figurhead
Thanks! I will check it out & ask him (just emailed him). So, are you sure that the 2008 pan & filter work for the 2003 6.0L F350 automatic tranny, without any mods? I'm assuming the pan has a required NEW gasket to purchase, too? I'm not familiar with the new filter location. The standard tranny filter/screen in the pickup is in the pickup tube, but where is the new 2008 full flow filter? Just prying your minds for info, since I am lacking. Thanks again for all the help.
Old May 18, 2009 | 07:47 PM
william_04_x's Avatar
william_04_x
We were talking about this in the Excursion forum..Click here for the part numbers...AFAIK, this will work on any 03-07 TorqShift..
Old May 18, 2009 | 09:45 PM
cartmanea's Avatar
cartmanea
Its a full flow filter that replaces the screen in the pickup. The new pickup is larger with a pleated filter instead of a screen. Yes, the '08 pan fits the '03 TorqShift, so you'll need pan, gasket, and filter for an '08 and you'll be set.
Old May 19, 2009 | 07:44 AM
w_huisman's Avatar
w_huisman
So do the 08s run both an internal and external filter?
Old May 19, 2009 | 11:29 AM
cartmanea's Avatar
cartmanea
No, when they switched to an internal filter they eliminated the external bypass filter. It won't hurt anything to have both though, I plan to just extend the change interval on the external filter.
Old May 19, 2009 | 11:39 AM
w_huisman's Avatar
w_huisman
I suppose "in-line" is better than a by-pass. Why else would they make that kind of change?
Old May 19, 2009 | 11:47 AM
cartmanea's Avatar
cartmanea
Correct, the new design filters all of the fluid before it goes into the pump, the old design let small particles go through the system.
