Weird tranny question. Help needed.
Old Jul 12, 2002 | 11:58 AM
theleetbeagle's Avatar
theleetbeagle
Hello. I've been having the following problem for the last couple months now.
My truck is a 96 F-150 Short Bed with the Mazda 5-sp. 33" tires with a 4.56" rear end. Clutch replaced about 5 months ago along with slave cylinder.
Before I have the 4.56" installed my truck was really hard to start out from a dead stop because the tires were so big. This problem was so bad that I paid mucho $$$ to have the gears changed.
Now I have another problem. I cannot start out without the whole truck violently shaking. I've tried a little clutch/little gas, little clutch/lotta gas....virtually all the combinations to start out smoothly and effectively...none have worked.
The transmission into all other gears is the exact same...truck just shakes and I cannot make a smooth shift.
What the heck is wrong? I personally think it could be the presssure plate? 100,000 miles.
What do you guys think?
NJK
Old Jul 12, 2002 | 08:28 PM
kspilkinton's Avatar
kspilkinton
Did the problem occur right after the gears were swapped, did it set in slowly? It could have been a result of trying to drive with the 33's and stock gears. Slipping the clutch to overcome the rolling resistance of the 33's could have warped the pressure plate.
If it happened right away after the gear swap, I'd say the shop owes you a refund and a rebuild. Try a 4.10 though. (IMO 4.56 is a bit low for 33's unless you're bogging and rock climbing)
-Kerry
Old Jul 15, 2002 | 08:07 AM
theleetbeagle
4.56"'s ARE way too low, but I didn't know what I was doing. I WISH I have 4.10's. Can't afford a rebuild, though.
To the guy that mentioned the pressure plate, and anyone else for that matter: Could it really be the pressure plate?
It did in fact set in slowly and not necessarily after the gear swap.
NJK
Old Jul 15, 2002 | 12:42 PM
91pcup's Avatar
91pcup
It sounds like you may have burn spots on your flywheel and clutch
plate. With those low gears it puts a tremendous amount of torque on
your clutch. I just replaced my clutch, pilot bearing and internal
slave cylinder and noticed one burn spot on the flywheel and one on
the clutch plate. My truck chattered slightly when starting off in
first gear, but now it feels like a new truck. With 100k on your
clutch this would be my first quess as to your problem.
91 f150
300 six w/M5OD 5 speed
140k miles
Old Jul 15, 2002 | 01:32 PM
jopey's Avatar
jopey
when going from the stock gears to the 4.56's you have relived alot of the bogging stresses on the drive line. it makes it easier for the clutch to enguage and easier on the engine.
There is no way going to the gears he did puts more stress on the clutch than was before the gear swap.
My guess is they never resurfaced the fly wheel. I had this happen, it sucked. eventually it went away after 40k miles. but I did the work and did not feel like taking it apart again. but since you paid someone to do this. they must fix the screw up.
Old Jul 15, 2002 | 07:21 PM
Ratsmoker's Avatar
Ratsmoker
To start out cheap and simple replace your u joints. I have seen many times where takeoff jumpiness is fixed by this alone. After that go with the advice above. It is good info.
Old Jul 16, 2002 | 12:22 PM
theleetbeagle
U-Joints were replaced two weeks ago to fix a different problem. The chattering is still here.
The clutch is not original. Replaced about four months ago. Why we didn't replace EVERYTHING then is beyond me.
The only thing the shop did was replace the rear end gears. The tranny work my father and I do ourselves.
So it is everyone's opinion that I replace the flywheel, pressure plate and maybe the clutch (again?)?
Thanks!
-Nick.
Old Jul 16, 2002 | 12:28 PM
Trail_Rider's Avatar
Trail_Rider
I agree with the above post, it sounds like a classic case of "clutch chatter". The flywheel/pressure plate was burnt with the original gears and tall tires and now that you've put in the lower gears it has accentuated an existing problem that you didn't notice before.
Old Jul 17, 2002 | 08:21 AM
theleetbeagle
Will the flywheel need to be replaced? I understand that the pressure plate and clutch should be, but flywheel is like major $$$, isn't it?
NJK
Old Jul 17, 2002 | 03:13 PM
lanero's Avatar
lanero
About $150 for a new flywheel. If it isn't too badly damaged, you should be able to have it re-surfaced at a local machine shop.
Roger Lane
Old Jul 18, 2002 | 10:26 AM
theleetbeagle
I just called Advance Auto Parts and they want $166 for the clutch kit inc pressure plate and
ONLY $38 for the flywheel. What the heck?
NJK
Old Jul 19, 2002 | 10:59 PM
Jimbare's Avatar
Jimbare
all alone in the world
they are trying to sell you an automatic flex plate, or the starter ring for a flywheel.
Old Jul 22, 2002 | 01:19 PM
theleetbeagle
No...it's the actual flywheel. Checked three different supplies. $35-$48, respectively.
NJK
Old Jul 22, 2002 | 01:30 PM
ringkong's Avatar
ringkong
hustler54
1983 - 2012 Ranger & B-Series
16
Jun 23, 2013 06:33 PM
xjpilot
Dec 6, 2011 04:46 PM
RobbyMartin
1997 - 2003 F150
May 16, 2010 05:53 PM
muff47
Jan 5, 2008 11:17 AM
acm05fsu
1997 - 2003 F150
29
May 11, 2007 02:34 PM
